How many watts do I need ?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2006, 12:28 AM   #1 (permalink)
sloppybeak's Avatar
View sloppybeak's Photo Gallery
Hi, I just bought a SuperQ box with 2 eight inch subwoofers, prbobably about 200 watts each subwoofer. Right now my amp is 100 Watts per channel.I am afraid I will blow those subs with too little power, cause i blew a few of those Wal-mart cheapo boxes with just the 6 and 1/2 inch regular woofers before with the same 100 watt amp, untill I put lower powered Sony 6 and 1/2 inch co-axials in the box, then no problems. Does this mean i should push those subs with a, like, 600 watt Sony amp or something?
1989 2wd 22R 170,000 mi.,Mallory Hyfire Igntion/coil,Magnacore wires,K/N filter,Silver-E Steer stablizr, Rear Swaybar,Edelbrock shocks,Cooper 205-70-14's/14X6 Steelies, LC Eng dbl. row time chain w/ cast iron oilpump, Porterfield R4S Discs/Carbon Kevlar drums, Ice Cold AC, Sony/Linear Pwr sound
sloppybeak is offline   Reply With Quote
Old 03-25-2006, 12:34 AM   #2 (permalink)
cam2Xrunner's Avatar
You will never blow a sub by sending it too little power.
You can however blow a sub by overdriving the sub by having the gain too high(clipping)
Do you have a link to the specs on the subs and a link to your amp model? Or do you at least know how the subs are wired and what ohm load they are?
Old 03-25-2006, 12:44 AM   #3 (permalink)
sloppybeak's Avatar
I think I know what the problem would be now. I blew my other speakers because i turned the volume up too high on them and clipped my little amp, which is a nice amp(linear power), but just not enough watts to crank into those speakers. The same thing would happen to the subs i have now am pretty sure now, so Im going to need to get a nice high power amp- a Sony or Pioneer to crank the fuggin sub.Thanks
Old 04-07-2006, 06:30 PM   #4 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
I think the problem was; they were Wal Mart subs and were bound to blow regardless.
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 04-07-2006, 07:12 PM   #5 (permalink)
View Mr Marv's Photo Gallery
As cam mentioned you cannot blow a sub with too little power! If that were the case every time you turn the music down you would blow up the sub, right?! One of two things happened that blew those subs-you thermally overloaded them (too much power) or you mechanically overloaded them (too much power). A clipped signal alone will NOT blow a sub. A clipped signal that sends too much power to the sub CAN blow a sub.
Example 1:
You have a sub that is rated for 100 watts RMS (can safely operate with a continuos 100 watts).
Your amp is rated at 50 watts RMS
Under heavy clipping your amp could theoretically produce 100 watts.
This will NOT blow the sub since the sub can handle 100 watts RMS and cannot tell if it is "clipped" power or "clean" power.
Example 2:
You have a sub that is rated for 100 watts RMS.
Your amp is rated at 75 watts RMS
Under heavy clipping your amp could theoretically produce 150 watts.
This CAN blow your sub however it is not the clipping that does it, it is the fact that you have sent more power than the sub can handle.
This scenario is why you will hear people say "I blew the sub by underpowering it" when in fact the opposite is actually what happened. It was "overpowered" due to the extra power clipping causes and the sub is not rated to thermally/mechanically handle 150 watts.
On another note, those old Linear Power amps are very underrated! My guess is it is putting out WAY more power than you might guess it is which is what actually blew up your speakers (and will possibly blow the new ones if they can't handle the actual power). My feeling is you don't need a new amp rather you need to have the gains properly set with a multi-meter to determine the actual amount of power you are sending the subs .
Mr Marv is offline   Reply With Quote
Old 04-07-2006, 10:39 PM   #6 (permalink)
sloppybeak's Avatar
Thanks. Great feedback!
Old 04-08-2006, 02:51 PM   #7 (permalink)
Luc
View Luc's Photo Gallery
Originally Posted by Mr Marv
As cam mentioned you cannot blow a sub with too little power!...This will NOT blow the sub since the sub can handle 100 watts RMS and cannot tell if it is "clipped" power or "clean" power.
Wrong!!!
You can and will damage any speaker when using a smaller-rated amplifier from noise/distortion when turned up too much, where the FETs are oversaturated, resulting in sending a square wave to the speaker. You can argue semantics, is damaged = blown? Nevertheless, the speaker WILL get damaged.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 04-08-2006, 05:01 PM   #8 (permalink)
I know I'm a "newb" here but I do know a little bit about audio.
Maybe this thread will help a bit:
http://www.carsound.com/UBB/ultimate...=023738#000006
If the names there are not recognizable to some, I will let you know several of the posters are top grade electrical engineers (RobM, werewolf etc), IASCA/USACi multi crown world champions (Mark Eldridge) as well as Manville Smith (msmith) from JL Audio.
Old 04-08-2006, 09:36 PM   #9 (permalink)
Originally Posted by Luc
Wrong!!!
You can blow speakers using any size amp if the gains aren't set properly. But you will not blow a speaker by using an amp rated for less power than the speakers are meant to handle. It's all in the gain setting. If you want to get louder, of course get more power, but by having a smaller rated amp and having the gains properly set you will not blow your speakers by sending them an unclipped signal of less power than what the speaker is rated for.
Stock Single Disc Watts??? publikohn 2nd Generation (2005+) 0 02-23-2006 08:45 AM
Gen 3.5 Alternator Amp and Volt Rating WhiteRabbit 3rd & 4th Generation (1992–1996 & 1997–2001) 20 11-22-2005 06:23 AM
Electrical Issues (Dont Know) oibone781 Audio, Video, and Security - Tech 24 10-17-2004 08:18 AM
enough watts LOCALCAR Audio, Video, and Security - Tech 2 02-26-2003 10:43 PM
I was wondering....... (Car audio questions) 3 TOYOTA General Discussion 14 08-06-2001 10:51 AM
