Amp/s Suggestion To Power These Subs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2006, 10:21 AM   #1 (permalink)
Nothin' But Thug In Me
View CamryOnChrome's Photo Gallery
Question Amp/s Suggestion To Power These Subs
Will My Phoenix Gold Octane R 15.0:1 Power Four 12" Infinity Kappa Perfect 12d VQ's?
Four 12" Infinity Kappa Perfect 12d Vq
  • Each Are Recommended At 400W RMS Power
  • Each Have A Peak Power Handling Of 1600W
  • Each Are Dual 4 Ohms
  • Sensitivity Is 89 dB
Phoenix Gold Octane R 15.0:1 Mono Amp:
  • RMS Power Of 500W x 1 @ 4 ohms
  • RMS Power Of 1000W x 1 @ 2 ohms
Also, Will My Phoenix Gold Octane R 5.0:1 Amp Be Too Much Power For One 12" Infinity Kappa Perfect 12d VQ?
Phoenix Gold Octane R 5.0:1 Mono Amp:
  • RMS Power Of 150W x 1 @ 4 ohms
  • RMS Power Of 300W x 1 @ 2 omhs
__________________________________________________ __________________________________________________ __________________________________________________ _
Scroll To Post #8
Scroll To Post #8
CamryOnChrome is offline   Reply With Quote
Old 03-30-2006, 10:27 AM   #2 (permalink)
cam2Xrunner's Avatar
If the Perfects are single 4 ohm then no, that amp will not be a good match. You could wire to a 1 ohm final load or a 4 ohm final load. That amp is optimized for most power at 2 ohms load.
If you were looking at Dual 4 ohm subs then you could wire it to a 2 ohm final load.
Are you open to other suggestions on amps and subs? Do you really need 4 subs? How about two higher powered subs?
Use this wiring guide to help figure out impedance loads.
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
Old 03-30-2006, 11:04 AM   #3 (permalink)
Question
I Am Sure About Buying The Four 12" infinity Kappa Perfect 12 VQd Subs...
I Just Want An Amp To Max. Out The Four Subs...Any Suggestion To Do This?
And Does Anyone Have An Answer To My Other Question Of The Phoenix Gold Octane R 5.0:1 Being Too Much Power For One 12" Infinity Kappa Perfect 12 VQd Sub?
Old 03-30-2006, 11:18 AM   #4 (permalink)
That One Guy...
View Corollacrazy42's Photo Gallery
The R 5.0:1 will not overpower one of them. Its 400watts rms for that sub. And that amp doesnt put that in any ohm independence. So you would be ok using that amp on one, bu it may seem a little weak I would assume.
Corollacrazy42 is offline   Reply With Quote
Old 03-30-2006, 11:20 AM   #5 (permalink)
Originally Posted by CamryOnChrome
I Am Sure About Buying The Four 12" infinity Kappa Perfect 12 VQ Subs...
I Just Want An Amp To Max. Out The Four Subs...Any Suggestion To Do This? Cost Is Nothing I Just Want The Best Amp To Get The Job Done...
This one will do it nicely.
http://forum.elitecaraudio.com/showt...hreadid=127803
http://www.dls.se/english/fstark/a6n.htm
Old 03-30-2006, 11:50 AM   #6 (permalink)
Question
I Just Want An Amp To Max. Out The Four 12" Infinity Kappa Perfect 12 VQd Subs...
The Subs RMS Recommended Each is 400W So Total Of 1600W, So I Need An Amp To Give Each 400W...
Old 03-30-2006, 12:18 PM   #7 (permalink)
I gave you my suggestion. I can get you a brand new DLS A6 for a little over 400.
DLS A6>>>>>>>>>>>>>>PG Octane Tenfold.
Old 03-30-2006, 02:56 PM   #8 (permalink)
Exclamation
The Five 12" Infinity Kappa Perfect 12 VQd's
  • Each Have A 1600W Peak Power
  • Sensitivity Is 92 dB
  • Each Are Dual 4 ohms
What Amp Will Max. All Five Dual 4 ohms 12" Subs Out With At Least 2000 Watts To Run Each At 400W RMS If Not Then 2500 Watts To Run Each At 500W RMS?
The DLS Amp You Suggested I Dont Think Can Do That..If I Need To Go With Two 1200W Amps I Will Do That But I Need An Amp/s That Will Make These Subs Pound And Hit...Hard...At 400-500W RMS Each
Anyone With Suggestions On Amp/s For My Subs Please Post
Old 03-30-2006, 04:40 PM   #9 (permalink)
That One Guy...
http://www.fusioncaraudio.com/produc...product_id=101
Here is an amp that is freakin huge and should get the job done effortlessly. I have heard that this amp is quite expensive though, but since you said money is no object a good grand or two should be nothing...
Old 03-30-2006, 08:47 PM   #10 (permalink)
View anoiel's Photo Gallery
money no option? get the zapco c2k4kw retails at about 7000 dollars and it will push your subs to death.
anoiel is offline   Reply With Quote
Old 03-30-2006, 11:08 PM   #11 (permalink)
Question
Any Sub $1,350 Or Under That Will Give Me The 2500W RMS Power, 500W Per Sub? But That Is A Great Amp That Will Make My Subs Hit Clean And Sound Flawless...
Beside These 7000$ Amps...
Especially An Amp You Know Personally That You Have Heard Being Used...
Old 03-31-2006, 12:05 AM   #12 (permalink)
Audiophile on a budget
View TakeABao's Photo Gallery
English. Please?
I'm sorry, I really want to help. But I can't understand a damn word you just said nor any of the ones you have been saying.
It's almost like you've completely ignored what Rob posted...
/////ALPINE | Helix | SOUNDSTREAM
TakeABao is offline   Reply With Quote
Old 03-31-2006, 12:09 AM   #13 (permalink)
If your saying that i havnt heard that amp your wrong. GOing to be real hard to get 1 amp to do 2500w. You could try 2 arc audio 2500(what i have to push my two flatlines) would give you 2000watts. or you can try 2 of these arc audio amps fd2100d. there going to be a little out you price range. could get two for about 1500-1800. Also could try to get 2 zapco reference 1100.1.
Old 03-31-2006, 12:12 AM   #14 (permalink)
Post
Sorry I Will Re-Write That Post...
Is There Any Subwoofer That Is $1,350 Or Under That Will Give Me The 500W RMS Per Subwoofer I Want, 2500W Total? An Amp That Is Great And Will Make My Subwoofers Hit Clean And Sound Flawless...Especially An Amp That You Heard Personally And Know It Sounds Clean And Great...
Beside These 7000$ Amps People Have Suggested...No Offense To Who Suggested Them But I Aprecciate It...
Old 03-31-2006, 12:16 AM   #15 (permalink)
Post
I Wasn't Implying That At All Sorry You Thought That...But If Its Going To Be Hard To Get One Amp To Do 2500W Do You Think One 3000W Amp Would Do The Trick? If So, Suggestion Please.
Need an amp to power this sub camryman1 Audio, Video, and Security - Tech 15 09-17-2005 05:04 AM
Subs, but no amp yet, where can I hook into... Ruffrydasean Audio, Video, and Security - Tech 11 09-07-2004 10:09 AM
