I've just installed a 2-way alarm remote starter for my 98 camry automatic, the alarm works fine but the remote starter doesn't. When I start the engine with my remote, its start (crank) like you would with a key for 1-2 second then the control box (alarm) relay kick out to shut off the engine, engine wouldn't stay on. * Do I need the (Tranponder Bypass Kit ) or the hand brake to be conected? if so to neg(-) or pos(+) lead. the alarm I bought doesn't have the Tachometer instead it has the oil preesure/alternator sensing. Start up, control box relay cut off (i can hear relay cut off). Is there any setting to the control box ?Any input is appreciated, thankx Guys
Category:Immobilizer BypassRequired:YesType:TransponderPart#:555XWNotes:When using the 555XW, the synch wire is blue/yellow, clock wire is red/blue, data wire is green/white, ignition wire is black/yellow, and ground wire is white/black.Alternates:556UW, DesignTech 20402, DesignTech 29402
Looks like you doo need an imobolizer bypass, so i'd get that. Also with a lot of these sensing units, they need to be "learned" so read up on how to make you system learn the proper functions.
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
This Is Beautiful, By the way my 98 camry key doesnt have a special chips ( just a plain regular key) will it need this immobilzer anyways? Is that the reason why its keep on starting and shut off after start? This is my first one. Thankx SMAN
Are you sure it's a plain key without a chip? You might want to consult your dealership on this just to make sure, but yes this can definatly cause starting issues cause it's designed to prevent the ar from being hotwired.
Besides that, like i said before, these units have a "learn" function in which you teach it the difference between car On and car OFF. You need to program that too otherwise it will just turn off after a few seconds cause it thinks the engine didn't start.
Only '99-up Camry with factory alarm has the transponder, so your '98 will not need the transponder bypass. You really need that tachometer wire (purple from the alarm/rs brain, I believe) since that's the easier way of learning the RPM. IIRC, there is a wire that needs to be grounded also, which is typically connected to the parking (hand) brake. What brand of alarm/rs system is this?
this is incorect as some of the 98s had the transponder feature. However I highly doubt yours has it.
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
I checked with the dealer, my car doesnt have the transponder, the purple line that need to connect to the charging out put or oil pressure, but I dont know how to make the brain to learn how to keep engine stay on. I also try to connected to the Tach wire too, the handbrake wire i also grounded (without grounding) the brain wouldn't start, but since B-wire is grounded thats why it start but wont stay running. is this one LUC. Look at the bottom wire diagram alarm with starter.
This sytem manual doesn't have learning funtion for some reason, I hooked the charging wire sensing to the (+) batt. terminal, now the alarm crank and engine turned over but shut off after it cranked,and the remote indicate the engine is running, ignition stay on light flashs as it supppose the egine is running but it's not, my key to start the car is a plain key (no speciak chips on it), any idea??
What did you hook the purple wire to?
Purple to (+) batt. terminal., what do you do with the key sense wire near the ignition cylinder, I try to unplug them to unlock/disarm manufacture alarm( i think).
