First off, Ohms is resistance, so naturally, 2 Ohms is going to be less resistance than 4 Ohms. Because of this, you can run more power at 2 Ohms. But you have to make sure that you get your subs setup for 2 Ohms using Ohms Law. keep in mind that you can run an amp rated for 2 ohms at 44 ohms, but it will put out a lot LESS power. but you don't want to run an amp stable at 2 Ohms down lower unless you know it can handle it, cause it will heat up somthing fearce if your not carefull.
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
