Cause of Death - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2006, 06:24 PM   #1 (permalink)
Super-ah
theKnifeArtist's Avatar
View theKnifeArtist's Photo Gallery
Question Cause of Death
i should of posted this a yay-while ago.
so i bought a audiobahn tube subwoofer. its an amp, an enclosure, and a speaker. i hooked it up once...hmm doesnt work. then we realized it was a bad ground...like zero ground. so then i hooked the ground up to the taillight screw(the screw and bolt behind the tail light)...so it worked. i drove home and it worked good. then all of the sudden, pretty close to my house, the sub shuts down.
when getting home i realize a blown fuse on the amp. i put another fuse in of the same amps and blown again. then my dad has the bright idea of sticking the fuse in...and then the power cable. thing starts smoking.
so...i checked the 12v and ground side of the amp and it shows a short inside. ok that explains why its not working but how would that happen? i sent it back and they gave me a new one and im about to put it together again...im gonna run the negative all the way to the battery this time..cuz i was told the power could of spiked and the ground wasnt good enough and caused it to blow.
what should i be aware of the second time i install this woofer.
thanks for any help
i didn't buy it from crutchfield but this is what i got.
http://www.crutchfield.com/S-hGruyow...0&I=037ATB10AT
theKnifeArtist is offline   Reply With Quote
Old 04-14-2006, 06:42 PM   #2 (permalink)
'96 Rolla DX
View SR5_4WD's Photo Gallery
Thats messed. A friend of mine has something very similar to yours and he has no trouble. I guess the bigger the ground, the better
SR5_4WD is offline   Reply With Quote
Old 04-14-2006, 10:45 PM   #3 (permalink)
94 Tercel
enerjohn's Avatar
View enerjohn's Photo Gallery
Don't ground the amp to stuff like taillights or accessories. ONLY TO THE CHASSIS.
You can use existing bolts or...
Drill a hole if you have to. Scrape the area with a wire brush to ensure bare metal to metal
contact.
Secure the ground with bolt and nut, and protect the connection with rubber cement
or silicone.
enerjohn is offline   Reply With Quote
Old 04-15-2006, 12:16 AM   #4 (permalink)
Super-ah
well the taillight screw and bolt was fastened to the chasis so i figured....
MSNBC: Man faked his own death to avoid child support Deuce Off Topic 0 01-22-2006 10:38 PM
Hooked fish gets revenge, lures angler to death Bishop13 Off Topic 4 08-16-2005 09:50 PM
The Hyde Death pool ... JekylandHyde MR2 Forum 9 05-31-2005 08:17 PM
Couple of night shots of the XRunner(56k Death) cam2Xrunner Show & Share 17 02-14-2005 05:26 PM
Death Scences....dats some weird shiznet! xavior66 Off Topic 2 07-21-2003 11:38 PM
