Sub Tear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-16-2006, 11:25 PM   #1 (permalink)
BigDaddyMike
View bigdaddymike745's Photo Gallery
Gen5 Sub Tear
hey guys, just received my POLK/MOMO subs in the mail. as i was installing them, the first one went perfect, but when i was screwing the othere one in, the drill slipped and tore a little hole in the rubber part of the woofer. the holw is a really small one. maybe like the diameter of a pen tip. but i can definetly feel the sound differece between the two subs. i was thinking bout buying some silicone and puting some over the whole so it gets sealed. what do u guys thik?
THE SAD PART IS THAT THEY ARE BRAND NEW AND I ALREADY MESSED 1 UP
Click to check it out. Its Sick
http://www.cardomain.com/ride/805128
bigdaddymike745 is offline   Reply With Quote
Old 04-16-2006, 11:47 PM   #2 (permalink)
cam2Xrunner's Avatar
Is the surround foam or is it infact rubber?
Old 04-16-2006, 11:59 PM   #3 (permalink)
This thread, in the second page has some good info from Rick.
http://forum.elitecaraudio.com/showt...5&pagenumber=2
Basically you need to put silicone on the bottom of the surround and on the top.
If you have a foam surround there is this special glue that works great.
http://decware.com/newsite/foams.htm
Last product on page, DAH25.
Old 04-17-2006, 01:46 AM   #4 (permalink)
BigDaddyMike
i have the rubber. and the crack is about 1cm in length. its really small. if i silicone it, will it ound like new of its already done with
Old 04-17-2006, 02:19 AM   #5 (permalink)
Yep, should be fine. You shouldn't hear much of a difference the way it is now, so check the seal on the sub where it contacts the box. Did you use a foam/rubber gasket between the sub and the box?
Old 04-17-2006, 02:58 PM   #6 (permalink)
BigDaddyMike
my qlogic box came with rubber gaskets for the subs. i drilled right throught them fo that tight fit with no leaks
Old 04-19-2006, 01:25 PM   #7 (permalink)
BigDaddyMike
i fixed the tear with rubber ement and now it hits the same as the other sub. thanx everyone
is this paint chipping normal wear & tear? (56k semi-ok) SolaraTRD General Discussion 19 03-17-2006 07:45 AM
After 3 years... on of our Accords is gone CDub LXi General Discussion 8 07-29-2005 09:35 PM
