Ditch the cap, get a fused distribution block to seperate the power to each amp, then have the ground wire from each amp grounded to the same spot, if possible, less than 18 inches or ground wire.
Some amps have a remote turn on output(mine does anyways). If it has that you can wire the remote turn on lead from the headunit to the speakers amp remote lead input, then from that amp's remote lead output to the sub amp.
If your amps don't have that, you can run sperate remote turn on leads to each amp from the headunit, or T off from the one remote turn on wire to the other. Do whatever is cleanest in your install.
