2001 Corolla Rear Speakers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2006, 10:10 AM   #1 (permalink)
ST184
View Rico's Photo Gallery
Question 2001 Corolla Rear Speakers
Hey guys, I need some help with this installation.
I can't figure out how to mount my speakers. I don't really want to drill any holes. Plus, I want to use factory speaker grilles. I don't know how those install either.
If anyone could give me some ideas, they'd be greatly appreciated!
I don't want to get them installed, I want to install them myself.
I would get factory speakers but they're $112 each.
Thanks..
Rico is offline   Reply With Quote
Old 04-24-2006, 11:39 AM   #2 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
To install the speakers you first have to take off the bottom of the rear seat (it just pops off if you pull up from the front), then remove the side of the seat between the seat back and the door. Both of these bolt onto to frame under the bottom seat cushion. Then, remove the rear third taillight cover. Once that is off you can pop off the rear deck cover that includes the speaker grilles.
After that it is easy to remove the factory speakers and install new 6.5" ones, which should have no problem using the factory mounts. If the speakers you want to use are not 6.5" you will need to buy an adapter so that they will fit.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 04-24-2006, 11:40 AM   #3 (permalink)
ST184
That's the thing, I don't have ANY mounts right now. I need ideas on how to mount the 6.5's i got..
Old 04-24-2006, 12:43 PM   #4 (permalink)
That makes more sense then. You should still have the factory mounting brackets in the back, as well as wires running back there (if not it wont be to bad to run them). It's cheaper for them to make all cars that way. Your only problem then would be having to cut through the rear deck. You may be able to find the factory speaker grilles on ebay, or from a car thats been wrecked, but if not you will most likely have to cut the hole to match the grilles that came with the new speakers.
Old 04-24-2006, 05:09 PM   #5 (permalink)
ST184
Originally Posted by gideon1331
...You should still have the factory mounting brackets in the back...
Nope.. that's what I mean, I only have the "holes" that the factory speaker mount slides into place. 2 rectangluar slots and 1 screw hole - looks like the bracket slides into the slots then you twist to lock and then screw down.
Can I buy these separate or are these the speakers itself that come riveted on.
Old 04-24-2006, 06:57 PM   #6 (permalink)
You could probably buy them seperate; the speakers are not rivited into the bracket. I am suprised that they are not in there from the factory, as it is usually cheaper to just have everything there except for the speaker so that all models are the same.
They may be hard to find tho. If you go to a local car stereo shop and can find someone who actually knows what theyre talking about, there may be aftermarket brackets you can buy.
Old 04-24-2006, 07:33 PM   #7 (permalink)
ST184
"You could probably buy them seperate; the speakers are not rivited into the bracket. "
How sure are you?
Because if you are, I'll buy them from the dealership.
1996 Corolla rear lip or rear bumper (AE102) Jaspher Archived Corolla threads 2 11-24-2006 02:10 PM
Who has upgraded their rear speakers? emiliorescigno Archived Corolla threads 15 08-12-2005 03:57 PM
2002 Corolla CE, rear deck removal hipstermcgee Audio, Video, and Security - Tech 1 08-05-2005 04:10 AM
94 corolla rear speakers salriv985 Audio, Video, and Security - Tech 2 02-03-2005 06:32 PM
Trying to install new rear speakers in a 2003 Corolla Wintermute6 Archived Corolla threads 3 01-31-2005 01:15 PM
