Increase your bass SPL/dB - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2006, 07:50 PM   #1 (permalink)
View fredster34's Photo Gallery
here's some facts for those wanting to design a sound system for more bass, especially deciding between sealed vs. ported boxes and amp wattage.
let's take a sub, a JL Audio 10" (10W0), for example. it handles 125W RMS and can be used in a sealed or ported box. it will work great in a 0.75 cuft sealed box and a 1.25 cuft ported box. for any given wattage, the sealed box will hit tighter and lower, while the ported will be louder. u can modify the sound of either box by changing box size and/or port size.
let's say the sub puts out 100dB at 125W in a sealed box (its probably lower than that). if wattage stays the same, the ported box will give a 3dB increase, so u'll get 103dB with the ported version.
for a sealed box, to increase SPL by 3dB, u have to double the power. so u can get 103dB from sealed if u feed it 250W. but now the speaker cant handle that much power.
so u have to decide what type of bass u want, accurate vs. loud. then decide how u want to increase SPL, by porting or by doubling the power?
one last thing, all else being equal, doubling the amount of subs will increase SPL by 6dB.
fredster34 is offline   Reply With Quote
Old 04-24-2006, 08:00 PM   #2 (permalink)
That One Guy...
View Corollacrazy42's Photo Gallery
IN most cases I would say you wouldnt wanna sacrifice the speaker by overloading it. Even more if the sub is just for normal use, because you will want it to last.
Mainly im not sure what you trying to get at though.
But ported will sound worse like you said but provide a little more db's. It is probably most beneficial to get a sub that can handle alot of power and has large excursion. This will produce the most about of air movement. So basically a big sub with a high power rating would probably be best. knwoing you can load the sub beyond its RMS power if need be. If you do design a port it shoul only be so big because you want the sub to still be able to rebound.
But even from your writings, you can tell the a sealed enclosure is the better outcome. You will get better sound, more accurate and loud too. Ported will sound sloppy and slow but *slightly* louder. You wont notice much difference in a 3db change.
Corollacrazy42 is offline   Reply With Quote
Old 04-28-2006, 09:50 PM   #3 (permalink)
View Y0tA _CaM's Photo Gallery
ported to me sounds way better. i had a 12" L5 in a ported box and then got a kicker ported enclosure and it made a huge difference. my friend had it in his car w/ 600watts and u could hear it from down the block.
I'm out like a fat kid in dodge ball!
Y0tA _CaM is offline   Reply With Quote
Old 04-30-2006, 07:54 PM   #4 (permalink)
Iceman91's Avatar
View Iceman91's Photo Gallery
I have had SO MANY SYSTEM SET-UP's and PORTED SQL box's are the best. They sound GREAT and hit HARD I made one for my set up in my sig and it is CRAZZZZZZZZZZZy LOUD & CLEAN. It is all the box design and make. I have built over 100 box's for my friends, fellow competitors, customers, & myself. It just takes experience, knowledge, and time to make the perfect box.
Now for what fredstar is talking about ya some is true, but it is all the amp efficiency, box, and woofers. What I usually do is make a sealed box for my woofers to brake the woofer in, then put them in a ported enclosure and you would be set.
2006 Toyota Highlander Hybrid Limited
Eclipse DVD/CD Indash
JBL Pro Mids & Highs Pheonix Gold Tantrum 600 x 4
Kicker L7 15 Dual 2ohm (custom ported enclosure)
Kicker KX1200 = 150.4 db (on dash)
Iceman91 is offline   Reply With Quote
Camry 02 - heavy bass in stereo system dbhatia Audio, Video, and Security - Tech 11 11-24-2006 11:41 PM
Running 150 Hz Bass Blockers for 4" speakers @ 4 Ohms Ukrainian102 Audio, Video, and Security - Tech 5 08-13-2005 02:19 PM
Bass tube? MDKonecky Audio, Video, and Security - Tech 16 04-08-2005 09:19 PM
Brand New RFX9020M Skipping From Bass Tricache Audio, Video, and Security - Tech 3 12-23-2004 11:07 AM
Audiobahn Bass tube vs Bazooka Bass Tube planetdon Audio, Video, and Security - Tech 13 11-20-2003 10:10 PM
