wire soldering? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2006, 08:23 PM   #1 (permalink)
corollapride's Avatar
View corollapride's Photo Gallery
wire soldering?
Hi, My speakers do not seem to get enough wattage and I think its because the wires need to be soldered. Will it make a big difference if I solder wires together, instead of just twisting it together. What about with the head unit wires? Thanks all.
corollapride is offline   Reply With Quote
Old 04-27-2006, 08:30 PM   #2 (permalink)
View anoiel's Photo Gallery
i dont believe that it makes a big difference but id use splice connectors instead of twisting them together with tape
anoiel is offline   Reply With Quote
Old 04-27-2006, 08:32 PM   #3 (permalink)
View gasman's Photo Gallery
if you had dirty hands when you twisted your wires together it might make a difference but only a little bit. i aleays solder my wires incase they get tugged then they wont fall apart and shortcircit as the case may be
Brake-Down Shift-Turn
gasman is offline   Reply With Quote
Old 04-28-2006, 02:18 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Twisting wires together + electrical tape = ghetto rigging.
Either solder + heatshrink or electrical tape. Or use insulated crimp connectors.
"Skoolin' the unlearned!"
Old 04-28-2006, 06:24 AM   #5 (permalink)
View netherland24's Photo Gallery
to get more "wattage" that isnt gona do shit..... u need a 4 channel amp for the speakers. radio's "aftermarket" put out anywhere from 9-24 nominal watts. factory radio 9-12 watts.
i was sorda laughing about the solder will make it better... naw just keeps it neat and nice, and have less problems of the wires coming apart.
netherland24 is offline   Reply With Quote
Old 04-28-2006, 04:03 PM   #6 (permalink)
View rexrunner's Photo Gallery
soldering will give you more power to your speaker, but it wont be a big difference. with soldering it creates less resistance and therefor more power can be transfered.
rexrunner is offline   Reply With Quote
Old 04-28-2006, 11:19 PM   #7 (permalink)
eeto........?
View _VVTi_'s Photo Gallery
solder is old school stuff, but gives the best electrical conductivity provided its not a cold joint.
butt splice is the fastest and possibly the most secure provided its done correctly.
but for me.... hehehe..... i take something call "Raychem" splices, which is specifically used in aircraft applications. I sneak those from work. They can't cheap, really really really high quality ones goes for about $5/pc.
1994 Camry LE V6
Tokico blues + Vogtland / Depo headlamps / Clear bumper light / Silverstar / AEM CAI / Tenzo R Formula 10 + Kumho 215/50/17
_VVTi_ is offline   Reply With Quote
Old 04-28-2006, 11:26 PM   #8 (permalink)
oh no get solder and heat shrink.... oooooo please not 1watt more... WOW...
01 Camry SQ project
Old 04-29-2006, 01:04 AM   #9 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
The difference is probably even less than that.
If they're currently twisted together, it'll be more secure to use crimp connectors like butt connectors or caps.
Solder is great if you have the skill and the supplies laying around to do it. Otherwise just crimp the things togehter. The difference is probably inaudible.
2007 Camry 2.4L 5M
Old 04-30-2006, 06:34 PM   #10 (permalink)
ooh i c, thanks all.
HOW TO: 2005-06 Fog Light Modification SWTRDSPORT 2nd Generation (2005+) 110 10-24-2011 07:40 AM
MSD Ignition luisitol Camry & Solara Lounge 23 03-15-2009 02:13 PM
Basic Amp Install Instructions Phi Audio, Video, and Security - Tech 11 04-06-2005 02:25 PM
extra battery 97avalonxls Audio, Video, and Security - Tech 9 09-20-2004 12:09 PM
Subwoofer Install? CamrySpeaksJL Audio, Video, and Security - Tech 17 02-07-2003 08:33 AM
