Pre-Out Voltage Q - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2006, 12:15 AM   #1 (permalink)
TN User
View MentatGom's Photo Gallery
Pre-Out Voltage Q
Hey All,
I currently have a Kenwood headunit with 2 volt Pre-Amp Outputs.
This is run to a 300RMS amp (with gain almost all full) powering a 10" sub.
When I am running the headunit at high volume (~15) the sub sounds great and balanced with my Highs and Mids run off the headunit. But I don't want to go deaf listening that loud.
At normal listening levels (~5) the sub is barely if at all audible.
My Question is whether a headunit with higher voltage pre-amps will offer more output at lower listening levels? Otherwise I am going to return this amp and subwoofer. It is past my return date for the headunit, so I have to live with it for now.
Thanks!
MentatGom is offline   Reply With Quote
Old 04-29-2006, 12:58 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
What amp do you have?
With higher voltage preouts, you'll need to lower the gains so that the amp doesn't overheat, so it's likely that the volume will stay the same. Have you tried playing with the equalizer or the subwoofer level controls?
2007 Camry 2.4L 5M
Old 04-29-2006, 01:16 AM   #3 (permalink)
TN User
Yes, I have adjusted everything.
On the headunit (Kenwood EZ500) I have adjusted the cross-overs, sub output level, bass settings, loudness settings... done it all over and over.
Amplifier is a Blaupunkt PCA1300 Mono sub amp. 300RMS @ 4ohms.
I have adjusted gain, cross-over, and level boost.
Power is going to an Infinity Reference 1050w @4ohms in a sealed 0.75 ft^3 box.
Sub is against back seats firing toward rear of car.
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
