power distribution - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2006, 04:34 PM   #1 (permalink)
View Y0tA _CaM's Photo Gallery
power distribution
ok...i wanna know how much power can in amplifiers can i push on stock alt. and battery on a 98 camry 4cyl? i eventually will upgrade battery and alt. but how do i know wat battery to get for a perf. alt.?
I'm out like a fat kid in dodge ball!
Y0tA _CaM is offline   Reply With Quote
Old 04-30-2006, 09:16 PM   #2 (permalink)
cam2Xrunner's Avatar
Do the Big 3 wiring upgrade and get a strong battery and I think your stock charging system can handle maybe around 40-60 amp draw from the sub amp and a speaker amp around the same.
In wattage, figure around 500-600 watts rms on the sub and a 75 watts rms x 4 amp for the speakers. Lot's of variables, just upgrade your wiring for the big 3 and get a stronger battery and you should be ok on a stock alt. that works as it should.
Big 3
http://forum.sounddomain.com/ubb/ult...c;f=5;t=007801
Old 04-30-2006, 09:48 PM   #3 (permalink)
well wat do u think for two kicker 1000.1s & a kicker 350.4, can the stock system hold it w/o dimming? i know i can run it but will it supply the power the amps ask for?
Old 05-01-2006, 02:18 AM   #4 (permalink)
You will definitely get dimming, but how bad...Not sure. You would definitely benefit from the Big 3, an Odyssey battery and a stronger alternator.
Old 05-01-2006, 04:01 PM   #5 (permalink)
thanx for the info! i appreciate it. i'll try that wen i get everything and get it hooked up.
Lexus History BLUEMEANIE General Lexus Discussion 8 11-25-2011 12:53 PM
power steering belt removal and crank pulley Q's CrawlingEye Camry & Solara Lounge 1 06-28-2005 04:51 PM
decrease in power! HELP! kasimmmmm General Discussion 17 04-21-2004 09:20 PM
