Box size - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2006, 01:25 AM   #1 (permalink)
Vanthusiast
hiace24's Avatar
View hiace24's Photo Gallery
Box size
After comparing my sub to a friends, i am reconsidering the size of my box. The size i have now was suggested by a friend but i am doubting that it is the right size. Can anyone from these specs please suggest the best size box? or suggest a foolproof program to calculate the size.
Power Handling: 300WRMS
Impedance: 4ohms (dual voice coil)
Voice Coil Resistance: 1.7ohm
Vas: 79.454Ltr
Qms: 3.238
Qes: 0.446
Qts: 0.392
Sensitivity: 88.152dB/Wm
BL: 9.992 TM
Fo: 28.77Hz
Sd: 514.720 sqCM
Thanks in advance
hiace24 is offline   Reply With Quote
Old 05-11-2006, 01:36 AM   #2 (permalink)
Frugle's Avatar
View Frugle's Photo Gallery
hmm, my MTX 10" with the same specs need .75 cubic feet each optimally...
Frugle is offline   Reply With Quote
Old 05-11-2006, 11:42 AM   #3 (permalink)
View Mr Marv's Photo Gallery
Vas: 79.454Ltr
Qms: 3.238
Qes: 0.446
Qts: 0.392
BL: 9.992 TM
Fo: 28.77Hz
Sd: 514.720 sqCM
Thanks in advance
What type/size enclosure do you have now and what don't you like about it compared to your buddies? Are they the same subs with the same amps in the same vehicle?
All of the computer programs I use (and have tried) can only calculate a certain alignment in an anechoic chamber. Unfortunately we don't drive anechoic chambers and every vehicle is different so you would need to know the transfer function of your particular vehicle in order to have an idea of how that sub will respond in your particular vehicle! This still will not be perfect and if you have a passenger or 2 everything changes anyway!
Mr Marv is offline   Reply With Quote
Old 05-11-2006, 12:25 PM   #4 (permalink)
View drehtwnftbl's Photo Gallery
look in the stickies thread....there is a site that has a box size calculator in it...
drehtwnftbl is offline   Reply With Quote
Ported Box Program? RedPhoenix Audio, Video, and Security - Tech 2 07-24-2005 07:31 PM
piston/bearing size WickedLexus96 Camry & Solara Lounge 11 07-05-2005 09:53 PM
1st time working with 'glass - tips needed. Phi Audio, Video, and Security - Tech 25 06-24-2005 03:54 PM
Busted Coin Box 99camryLE Camry & Solara Lounge 3 06-24-2005 11:07 AM
