Amp reinstall help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-16-2006, 01:33 PM   #1 (permalink)
View fredster34's Photo Gallery
Gen5 Amp reinstall help!
i took out my amp and sub a month ago, now i'm trying to reinstall them. i rewired everything correctly. but when i try to put the inline fuse back (on the power wire), the fuse blows? i never had that problem before. i've gone thru 3 fuses already.
the original fuses are:
1 30A inline fuse
2 20A amplifier fuses
the 30A (inline power) fuses get blown when i put it in the fuse holder. i made sure that nothing is turned on, even the key is out of the ignition, and the fuse still blew. shuld i rewire the amp in a certain order or sumthin? wut am i doin wrong? theories, guys...
fredster34 is offline   Reply With Quote
Old 05-16-2006, 01:44 PM   #2 (permalink)
Smell the Audiophiliacity
LiquidClen's Avatar
View LiquidClen's Photo Gallery
is your fuse to small?
LiquidClen is offline   Reply With Quote
Old 05-16-2006, 01:54 PM   #3 (permalink)
cam2Xrunner's Avatar
Disconnect your battery.
Old 05-16-2006, 02:31 PM   #4 (permalink)
thnx
thnx, i'll try that. but i never had to do that before? wut gives?
Old 05-16-2006, 06:24 PM   #5 (permalink)
LiquidClen's Avatar
You should always do that. I'm surprised you didn't blow your ACC fuse
Old 05-17-2006, 05:21 PM   #6 (permalink)
Gen5 negative
well, i looked at the Crutchfield tutorial on amp installation. they say to disconnect the negative battery terminal first. i did that, then i connected all the amp wires n fuses, then put back the negative battery wire. everything was fine. looks like i'll use this procedure from now on.
Old 05-18-2006, 04:58 AM   #7 (permalink)
View TRDGen5.5camry's Photo Gallery
you always disconnect the negative side of the battery when your doing wiring to the car.
TRDGen5.5camry is offline   Reply With Quote
Old 05-18-2006, 11:21 AM   #8 (permalink)
View drehtwnftbl's Photo Gallery
der?
drehtwnftbl is offline   Reply With Quote
Amp Installation help dave_thomas Audio, Video, and Security - Tech 6 04-29-2004 10:53 PM
