Need help with alternator whine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2006, 05:39 PM   #1 (permalink)
View Mitsouko1's Photo Gallery
4th Generation Need help with alternator whine
When I install a Pioneer EQ (DEQ-7600) i recently got, I get considerable alternator whine but without it everything is fine and it disapears. I have a Pioneer Head Unit running to a JBL and Infinity amplifier. I cant figure out what is causing it and any help would be welcomed.
Mitsouko1 is offline   Reply With Quote
Old 06-01-2006, 09:21 PM   #2 (permalink)
That One Guy...
View Corollacrazy42's Photo Gallery
I think this might just happen if you have two amps or something.. mine does it too. I heard you ground for both amps need to be close together and that can cause some noise.. but really it doesnt bother me
Corollacrazy42 is offline   Reply With Quote
Old 06-02-2006, 11:14 AM   #3 (permalink)
View drehtwnftbl's Photo Gallery
if it's the alternator whining, it just means that the alternator is trying to keep up with the demand for power. you might burn the alternator out faster than normal
drehtwnftbl is offline   Reply With Quote
Old 06-03-2006, 01:11 PM   #4 (permalink)
I have both the amps grounded to the same location in the trunk and have a new high output alternator so I dont think thats the problem. Everything works fine without the eq installed, only when I install the eq do i get the problem. Maybe try a new ground for the headunit and eq????
Old 06-04-2006, 07:42 AM   #5 (permalink)
View Fever's Photo Gallery
Yes, try new ground point for the hu and eq.
Alt whine coming thru the speakers is usually a ground problem.
'97 Camry XLE
Fever is offline   Reply With Quote
Old 06-05-2006, 10:04 PM   #6 (permalink)
Vanthusiast
hiace24's Avatar
View hiace24's Photo Gallery
Get a noise filter.
They look like this:
They are effective against 'engine hum' and 'ticking' caused by alternators, ignition coils & spark plug leads
hiace24 is offline   Reply With Quote
Old 06-06-2006, 01:56 AM   #7 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
what you need is a "ground loop isolator" either than or re-run your wires...pioneers tends to have the alternator whines.. i have a pionner HU and i get it then i re-arranged the power to amp wire away from all the speaker wires and it went away
Old 06-11-2006, 07:09 PM   #8 (permalink)
View rexrunner's Photo Gallery
first off, that whine from the over use of an alternator is a old wives tale. the whine is caused from a bad ground (paint not scraped off) or the power wires being ran to close to the patch cables (RCA). try to check your grounds and then check the rca's.
rexrunner is offline   Reply With Quote
