How Big a AMP you need? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2006, 06:13 AM   #1 (permalink)
Man of the Year
View haschen's Photo Gallery
Say you have a 800 watt sub how big an amp is there a golden rule to how large a amp is needed? I thought you shouldnt have a amp lager then the wattage it is sposed to be supplying...but i dont know
thanks
haschen is offline   Reply With Quote
Old 06-03-2006, 08:31 AM   #2 (permalink)
Smell the Audiophiliacity
LiquidClen's Avatar
View LiquidClen's Photo Gallery
Generally you wan to match the subs Watts RMS with the amos Watts RMS. For example, if your sub is rated at 1200W RMS, youll want to get an amp that put out 1200W RMS. You also have to match impedances. If you sub woofer is a dual 2 ohm woofer, you would want to get an amp that does 1200W RMS at either 1 ohm or 4 ohms. Also, you could get an amp that is slightly stronger than the subs RMS ratings, and if properly setup, you would have no ill effects. You could also go lower without a problem. I will be running in a couple days an Arc Audio Flatline Subwofer which is rated at 1000W RMS/ 2000W Peak and will be pairing it to an MB Quart RAA2400, which puts out 800W RMS.
LiquidClen is offline   Reply With Quote
Old 06-06-2006, 09:35 PM   #3 (permalink)
Australian TN'er
View Phat Devil's Photo Gallery
A sub can never have too much power. You can theoretically run a 5000w rms am into a 1000w sub as long as the gains on the amps are set correctly. But saying that, I always go for an amp that has a little bit more than what the sub needs. So for a 800w rms sub, i'd put a 1000w rms amp there for the bit of head room.
But mind you, unless you are going to be playing tones, it will usually only need about 500w rms to go plenty loud in a daily driver.
Whine addiction!
Phat Devil is offline   Reply With Quote
sugest a big amp sajnaj Audio, Video, and Security - Tech 19 02-16-2006 11:06 AM
Took out old stereo and found an amp on Gen3 camry!! fernicus 3rd & 4th Generation (1992–1996 & 1997–2001) 9 03-14-2005 01:30 PM
