Help! Strange remote starter gremlin... - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 6 Old 01-25-2017, 02:11 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Lightbulb Help! Strange remote starter gremlin...
Hey guys I am completely stumped and need some advice.
I recently installed a remote starter and byplass module on my GF's 2013 Corolla. Its worked fine for the first week or so. But now 1/10 times she starts it, it will only turn over and wont stop turning over until she hits the stop button on the remote... and stranger yet it has happened when starting the car normally with the key in the ignition... Thinking the immobilizer is preventing it from starting, but why randomly and why when the remote start isn't even triggered?
Avital 4105L and Directed DBALL2 bypass.
Any one with experience with these things, help would be hugely appreciated!!
Dwight Barnard is offline
post #2 of 6 Old 01-25-2017, 03:08 PM
Toyota Fanatic
Camry_wiz's Avatar
Quoted: 193 Post(s)
Do you have access to techstream? This sounds to me like a crankshaft position sensor to me which may or may not throw a CEL but is logged with TS. The immobilizer bypass should not be active when using the key, only when remote started. So the bypass and key in theory should be independent from each other but how it was wired could say otherwise.
2007 Camry SE 2.4 - Modded
2004 Corolla S 1.8 - Stock
2004 Lexus RX330 3.3L - Stock
Check out my DIY backup camera install on my Gen6 Camry!
Camry_wiz is online now
post #3 of 6 Old 01-26-2017, 06:42 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
I can check it for engine codes yes. The timing would be highly coincidental if it were the crank sensor but could be! I'm starting to think the second starter wire relay I wired up is getting a contact signal and staying closed keeping the starter running . But when it happens the car doesn't ever start.. so I think its more than a faulty relay...
post #4 of 6 Old 04-14-2017, 11:18 PM
Duck
freakbrian's Avatar
Quoted: 8 Post(s)
Did you have to cut any wires when wiring in the DBALL2, or only splice?
1991 Camry DX I4 Auto - Dark Grey Metallic
2007 Camry Hybrid - Desert Sand Mica
2006 Highlander Hybrid - Sonora Gold Pearl - RIP
freakbrian is offline
post #5 of 6 Old 04-15-2017, 12:21 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
I didn't have to cut any wires. I ended up just removing the second starter wire and now everything works perfectly. Not sure why it calls for a second starter wire.
post #6 of 6 Old 04-15-2017, 11:35 AM
Duck
freakbrian's Avatar
Quoted: 8 Post(s)
You should hook up the second starter wire by practice (sometimes on cars like 4Runner, it won't start in the cold without second starter wire hooked up). It's strange that it would cause issues though.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Audio, Video, and Security - Tech
User Tag List
Linear Mode Linear Mode
Back
