Help me with Setup... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2006, 03:08 AM   #1 (permalink)
View Budzeno's Photo Gallery
Ok so i have 2 Alpine 12" type R's in a sealed box, that i bought off a freind in my 97 toyota camry.They are not hooked up to anything they are just in the trunk now. And i was woundering what kind of amp + equipment would be best. All suggestions welcome!
Budzeno is offline   Reply With Quote
Old 07-08-2006, 01:21 PM   #2 (permalink)
That One Guy...
View Corollacrazy42's Photo Gallery
Well as a suggestion I would say to take out the subs and keep them inside for now until you get an amp. There is always the fear of them getting stolen before you even get to listen to them.
As for the amp, I will help later, Dont have tiem right now
Corollacrazy42 is offline   Reply With Quote
Old 07-08-2006, 02:16 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
How much do you want to spend?
Do you know any more specs on the subs, ie dual or single voice coil and the resistance of the voice coils?
2007 Camry 2.4L 5M
Old 07-08-2006, 09:54 PM   #4 (permalink)
Um no i know nothing else about the subs, um im trying to spend less then 400 total
Old 07-11-2006, 09:21 PM   #5 (permalink)
View jazz391's Photo Gallery
4th Generation
less than 400 total is very possible. if you have a drill, take the speaker out of the box and that should answer the question about the resistance of the voice coil(s). the sub has either dual 2 or 4 ohm voice coils. this information is very important in picking an amp. you are looking for something that will put out between 600-800 watts rms. if you are looking for an amp that will give you the ability to upgrade later, i suggest going with something that will do 400-600 rms at 2 ohms or 4 ohms and 800-1000 watts rms at 2 ohms or 1 ohm.
for sale: Cadence a6 (awesome 6 channel amp), pioneer premier 860mp head unit, kicker solo baric l7 8, 2 image dynamics idv3 12s, q logic 4runner box and custom 4runner box, diamond audio hex components 6.5 and 5.25 midbass
custom boxes (just send me an e mail at kuno2no@yahoo.com)
jazz391 is offline   Reply With Quote
Old 08-14-2006, 02:19 AM   #6 (permalink)
Update:
Ok well i took my car to a car audio guy i knew and he set up my system. I got a 100 watt Sony amp + the 2 12" Alpine type R's i already had. He Ran some wires and switched my sealed box to a ported. It Sounds good to me, but what do i know. Give me your input!
Old 08-14-2006, 02:24 AM   #7 (permalink)
BTW.... All under 400$
Old 08-14-2006, 03:01 AM   #8 (permalink)
That One Guy...
100 watt sony amp.. for some reason i think you ment to put 1000 watt, and even then.. not even close to what it does. The only reason its under 400 is because of the $10 amp though. Type R's don't sound bad though, so it probably sound decent anyways.
My system setup WickedLexus96 Audio, Video, and Security - Tech 6 12-14-2004 04:35 PM
Megasquirt setup in the AW11 toyotaspeed90 Archived Corolla threads 5 11-02-2004 04:20 PM
Raising the efficiency of your turbo setup AngryAE101 Archived Corolla threads 4 12-22-2003 11:07 AM
Gen 4 Eibach Solara/Camry spring setup. cheeba Solara 0 10-24-2003 09:11 AM
