Good question
Well let's see from what i can remember,
Where does it seem like the sound is coming from? the front center of the car? or the front far right of the car? If it is coming from the front center of the car then all is well i believe. But if it is coming from the front far right of the car, then possible you are right about the direct HU wiring being better then the factory wiring. As far as that goes, i wouldnt think factory wiring or direct wiring to the speaker would make a difference because even though better grade wire may improve wattage performance, i dont think an oem headunit can pump that much wattage to make any difference. But then again how old is the car iteself, if it is kinda old it is possible that the oem wiring can be fautly. Just my unprofessional 2 cents
