DEH-P860MP face doesn't open
I was trying to change the disc in my player yesterday afternoon but for what ever reason, the face would not slide down no matter what I tried. There was absolutely no way for me to open the face. When I pressed the button, the unit would beep and do nothing. Holding the button down had similar results. I turned the unit off and set auto flap open to true (the flap opens automatically when the car is shut off so that you can remove the face). The flap would absolutely not open. Even reseting the unit did nothing. I shut the car off for 10 min and tried it again and still the same.
So I was stuck listening to Utada and Ayumi during the afternoon....
This morning I tried to open it and it opened right away.
I think this might be temperature related because it was 30 deg cooler in the morning 85F vice 115F. Other than the face problem, the unit functioned fine. The sun sits in the car all day, so the temperature inside the car was probably even hotter. The water in my water bottle was hot enough that it was not drinkable - think hot coffee or something you'd use cook cup noodles.
2007 Camry 2.4L 5M
