Gen 5 camry 02-05, How easy is it to swap out the headunit? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-03-2006, 08:39 AM   #1 (permalink)
Banned
View plunk10's Photo Gallery
I'm considering the purchase of a Camry from generation 5 (2002-2006).
How easy is it to install an aftermarket head unit? Does it require any extensive work to the dash? Are there any walk-throughs here on this site or elsewhere?
Finally, any pics of your setup?
plunk10 is offline   Reply With Quote
Old 08-03-2006, 10:33 AM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
you just need a dash kit and wiring harness. you pull the heater control panel under the stereo and pry off the vent surround. from there you have full access to the stereo. remove the stereo. wire up your two harnesses. install the stereo into the dash kit, plug your harness to the car and the other end to the stereo, screw the kit and stereo into the car, snap the panel back on, install the heater controls and viola'.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 08-03-2006, 10:50 AM   #3 (permalink)
Banned
good. sounds easy enough. I've done head unit installs on a few cars now (all easy jap car installs), so it sounds like a piece of cake. Thanks for the info!
I was actually considering a 2003+ Honda Accord, till I found that the stereo is not as easy (nearly impossible) to replace.
Old 08-03-2006, 11:02 AM   #4 (permalink)
mazdaverx7's Avatar
they do make a dash kit for it. the 04+ is the kick to the dick to find a kit for.
85 RX-7 GS 5spd
Old 08-03-2006, 11:18 AM   #5 (permalink)
Banned
that figures. I was considering an 05 too.
Gen 5 Camry XLE Speaker Upgrade Convert Audio, Video, and Security - Tech 28 05-05-2008 01:51 PM
05 Camry different than 02-04? p@nda 5th & 6th Generation (2002-2006 & 2007-2011) 16 02-28-2005 01:39 PM
Buying Gen 4/4.5 Camry...Advice? islandboy57 3rd & 4th Generation (1992–1996 & 1997–2001) 12 12-05-2004 03:48 PM
Changing out strut mounts and spring bumpers - Advice needed (4th Gen Camry) Bob_98SR5 Camry & Solara Lounge 6 03-01-2004 07:17 PM
