Popping noise when turning on Head unit. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-19-2006, 03:09 PM   #1 (permalink)
View MafFilms's Photo Gallery
Whenever i turn on my cd player right when i get in the car, about after 5 seconds, i hear a pop noise..not a high pitched noise..like poo-pfh. Everything sounds ok after that i just want to figure out whats causing that it never did that before. My amp and everything is running fine im not overpowering it or anything. Any ideas?
MafFilms is offline   Reply With Quote
Old 08-20-2006, 12:35 PM   #2 (permalink)
That One Guy...
View Corollacrazy42's Photo Gallery
sounds like something might not be connected well enough, and is maybe causing the speakers to get an electrical jolt when you turn it on. Maybe a ground connection possibly? Double check your wiring
Corollacrazy42 is offline   Reply With Quote
Old 08-20-2006, 03:53 PM   #3 (permalink)
I forgot to add it only does it when a cd is playing as soon as it loads up, like if i turned the cd player off while it was playing...only does it like that.
Old 08-21-2006, 12:21 AM   #4 (permalink)
View mikegett's Photo Gallery
Most turn on pops are due to the amplifers seeing the voltage prior to powering up. The sudden surge of votage causes the amp to send out a poping sound. To eliminate this amps and some HU's will put a delay onto them. This means the amp can power up prior to seeing the HU's voltage. Since you didn't have this sound previously you amps delay circuit (a simple relay) or your cd's delay circuit (programing) may be defective. Did you change our your amplifier recently? If so, your new amp may not have a turn on delay. If it is the same amp, and since you state that it is only on the cd portion I would guess the HU has become defective. If it is out of warranty, then sounddomain and crutchfield both sell simple relays to plug onto your amp turn on signal. It will delay the amp from turning on long enough to avoid the popping.
mikegett is offline   Reply With Quote
Old 08-21-2006, 09:07 PM   #5 (permalink)
is this harmful? i usually take the cd to avoid this problem tho.
Old 08-31-2006, 07:51 PM   #6 (permalink)
If you keep the HU at high levels when switching it might shorten the speakers life span. At the least, you can press mute as you change.
Old 09-02-2006, 10:36 PM   #7 (permalink)
It doesnt do it anymore with my new amp, musta been the cheapness of the first one.
5efe head gasket still leaking, I need advice fast !!! reezytercel Tercel, Paseo, Starlet, and Sera Forum 9 05-24-2010 12:26 AM
Echo Sportivo - Head Unit echochick Yaris, Vitz and Echo Forum 1 08-18-2006 09:35 PM
Equalizer / amp without a head unit? HomeGrown Audio, Video, and Security - Tech 2 08-16-2006 10:27 PM
Popping Noise when turning the wheel kimmcc RAV4 Forum 5 08-11-2006 02:33 PM
New head unit question—by pass the factor amp or not (97 Avalon)? sickwilly Audio, Video, and Security - Tech 2 07-16-2006 07:52 PM
