Satilite Radio Wiring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-22-2006, 10:18 AM   #1 (permalink)
View xenocamry's Photo Gallery
Is it safe to wire the power supply for it to my cigarette lighter power supply? And does the antenna need to go outsid of my car or can I put it anywhere?
xenocamry is offline   Reply With Quote
Old 08-22-2006, 12:04 PM   #2 (permalink)
Jeeper in a Camry Body
View TXST8tj's Photo Gallery
the best reception will come from the antenna mounted in the highest, unobstructed spot on the car....usually the roof. however, you can still get great reception with the antenna mounted on your trunk and some places inside like the deepest part of the dash. you are more likely to experience reception issues with it mounted on the dash or rear deck because you are adding one more obsticle for the signal to hit. i had my antenna mounted on the hood hinge of my wrangler and never had a problem with reception.
if you are worried about having to run the wire to the roof, just run it back to the trunk area and mount it on the trunk lid.
as for the wiring, it would be best to run it straight to the battery.
07 4Runner SR5
TXST8tj is offline   Reply With Quote
Old 08-22-2006, 05:40 PM   #3 (permalink)
"ROCK ON"
rooster56's Avatar
View rooster56's Photo Gallery
Be sure to check and see what the voltage amount is from the supply to the satellite unit. My SkiFi 2 unit operates on 6 volts from the supply to the unit. The supply unit converts 12v to 6v. Just keep this in mind when you go to connect up the power supply. I bought a female plug (looks like a cigerette lighter plug with two wires) and wired it into the lighter connections, then hide the plug underneath the console, with the radio power supply plugged in. Good Luck!
Ha! Ha! Had them all out there stepping and fetching like their heads were on fire and their azzes was catching!!!
rooster56 is offline   Reply With Quote
Old 08-22-2006, 09:11 PM   #4 (permalink)
IT works soo far
I probly should have bought the female plug and wired it that way. It would have been easier. As of right now it works fine, although I have lost the use of my cigarette lighter (I never used it anyway).
Thanks
Old 08-23-2006, 02:55 PM   #5 (permalink)
How Ya Like Me Now?
View Anshu's Photo Gallery
if this is a long term solution Id consider hardwiring the unit to the battery for sleath
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
Anshu is offline   Reply With Quote
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 12:48 PM
Need help immediately stock radio wiring??? Willys Audio, Video, and Security - Tech 2 12-02-2005 11:27 PM
Strange wiring in radio. skybandit Audio, Video, and Security - Tech 4 08-19-2005 07:10 PM
radio wiring harness wormhole Audio, Video, and Security - Tech 6 12-04-2004 02:56 AM
radio wiring problems homeguard Audio, Video, and Security - Tech 3 05-06-2004 06:55 PM
