Fire Fire Fire - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2006, 11:20 PM   #1 (permalink)
BigDaddyMike
View bigdaddymike745's Photo Gallery
Gen5 Fire Fire Fire
hey guys today i came across something frightening. i was driving normally and all of a sudden my car started smoking. i got out of the car, poped the hood and there were flames everywhere. i put them out with my shirt and observed the situation. The amp wire from the battery to the fuse cought fire. luckaly thats the only thing that got burnt. why would it do that? someone told me that it cought fire cuz i have a 100AMP fuse in my fuse box. tomorrow i will redo the wiring. but i really want to kno what happned so it does not happen again. Im also investing in a fire extinguisher now. lol
Click to check it out. Its Sick
http://www.cardomain.com/ride/805128
bigdaddymike745 is offline   Reply With Quote
Old 08-24-2006, 11:33 PM   #2 (permalink)
silverxls's Avatar
View silverxls's Photo Gallery
could be right. if the wire running to the fuse box is not rated to carry 100 amps, then it could overheat and burn without blowing the fuse, but something had to be drawing all those amps...a short or huge draw somewhere. is 100 amp the size that came in the car originally?
silverxls is offline   Reply With Quote
Old 08-24-2006, 11:37 PM   #3 (permalink)
BigDaddyMike
Gen5
it is a 4guage wire. i had that setup for a year and a half now. i am still confused
Old 08-24-2006, 11:52 PM   #4 (permalink)
silverxls's Avatar
well, that could work forever, until something went wrong....lol seems that now comes the tedious task of finding the short or huge draw that pulled enough amps to burn the wire.
Old 08-25-2006, 12:04 AM   #5 (permalink)
touringcamry's Avatar
Gameroom cash: $510725
What kind of amp are you running?
Can you go with a smaller fuse?
2007 Camry 2.4L 5M
Old 08-25-2006, 01:33 AM   #6 (permalink)
How Ya Like Me Now?
View Anshu's Photo Gallery
Id say you were pushing the 4 gauge a little to far. What amps are you running and what are the fuses on them. Also what quality wire were you using?
Did any fuses go? Everything still working?
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
Anshu is offline   Reply With Quote
Old 08-25-2006, 04:30 AM   #7 (permalink)
BigDaddyMike
Gen5
hey how are you guys. i have a kiker amp which has around 1000Watts RMS and im using a MTX amp which is 200 RMS. Both amps are connected to a cap and the cap is powered through the wire that cought fire.
Old 08-25-2006, 08:21 AM   #8 (permalink)
With that kind of wattage, you should consider running a larger wire.
http://www.bcae1.com/images/swfs/sys...nassistant.swf
Use this tool to determine you wire gauge
2007 Camry 2.4L 5M
Old 08-25-2006, 06:08 PM   #9 (permalink)
View Y0tA _CaM's Photo Gallery
that happened to me in my camry. reason being the battery tie down was touching the positive terminal on the battery and the power wire from the system was touching the battery tie down and the plastic thing under the battery caught fire and the plastic coating on the power wire melted. it got so hot it like welded the bolt onto the battery tie down and the screw that holds it down broke off. i took a shit when i saw smoke coming out my hood
I'm out like a fat kid in dodge ball!
Y0tA _CaM is offline   Reply With Quote
Old 08-28-2006, 03:10 PM   #10 (permalink)
View rexrunner's Photo Gallery
wait you said from the battery to the fuse right? that wire is not fused yet then, maybe it shorted out?
rexrunner is offline   Reply With Quote
Old 09-01-2006, 09:23 AM   #11 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $132020
View mazdaverx7's Photo Gallery
how are your grounds? a bad ground can lead to a fire like that in a hurry.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 09-01-2006, 08:51 PM   #12 (permalink)
View mikegett's Photo Gallery
I would suggest having your amp and capacitor tested. Either one could cause a large current draw if something fails. Your cable prior to the fuse may have caught fire first due to weathering. The heat in the car bay will break down the insulation and make it more suseptable to failure over the interior cable. Deffinately think of lowering your fuse rating or increasing the wire gauge. 4 is pretty good, but overkill is better than having a fire.
mikegett is offline   Reply With Quote
Camry fire hazard? / Camry's Catch Fire mizunox Camry & Solara Lounge 30 11-26-2005 12:37 PM
Fire Forces Halt To Prius-making Toyota Unit's Operations lexusis350 Toyota News 2 11-22-2005 06:17 PM
No Fire or Spark sloopy General Discussion 0 07-05-2005 07:58 PM
05 Tc Catching On Fire Today redheadedkittu 1st Generation (2005-2010) 20 06-10-2005 03:29 AM
