Quick Amp check? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2006, 07:52 PM   #1 (permalink)
View 2olforthis's Photo Gallery
4th Generation Quick Amp check?
Recently bought an amp of ebay with unknown working condition (BOSS 650). I don't have any of hook-up wiring yet and don't want to invest unless minimal signs of life are present. Any suggestions of quick tests for power? I currently have decent gauge speaker wire. Would power connections using this with a ground be OK and not damage the amp for a brief period. Any knowledge would be appreicated.
2olforthis is offline   Reply With Quote
Old 09-14-2006, 09:27 PM   #2 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
Best thing to do would be to just hook it up to the car normally. Thats what I'd do. Don't forget the fuse. What is "decent" guage? Also whats the rms output of that amp?
Curry is offline   Reply With Quote
Old 09-14-2006, 09:52 PM   #3 (permalink)
My object is to find out if this thing even powers up before spending any money on cables, etc. I have 16guage wire. I'm literally talking about seeing if the power light goes on rather than determining full functioning. However, since I know nothing of electronics, I'm not sure if what I can think to do can be done SAFELY with what I have to work with.
RMS is 75W x 4
Old 09-14-2006, 10:09 PM   #4 (permalink)
View mikegett's Photo Gallery
You can do a quick test with speaker wire. Run a quick 12 volt positive and negative from the battery to your amp. I would simply place the amp on a table next to the car. Hook up a 12 volt positive to your amp turn on. Turn your gains down all the way. If you have a portable walkman, ipod, or cd player then plug a minijack to rca adaptor into the headphone jack. Turn on the portable device and it will output under one volt at max volume. Most are in the milliamps. Your amplifier will have voltage sitting idle at this point. Its consumption will be roughly under a amp with no load (that means speakers) on it. Your speaker wires are going to be able to pass the voltage. It is the high amperage associated with a speakers consumption that will cause it to fry. Place a multimeter on the speaker leads and set it to ac voltage over 100. If you aren't getting any reading, then increase your gains and portable device volume. Check all speaker setts. They should read very close to the same reading. The actual votage will vary greatly due to the amps RMS potential, input voltage of the source device, and gain setting. Just be sure to secure the temporary wires so that they don't fall and short anything out. The last thing you want is to have the power wire hit your amp case and ground.
mikegett is offline   Reply With Quote
Old 09-14-2006, 10:52 PM   #5 (permalink)
Looks good. I'll give it a try. Thanks.
Old 09-23-2006, 02:52 PM   #6 (permalink)
Got power!!! Great tip for a noob. Install kit will probably cost me more than the $21 I paid for the amp on ebay but at least now I know that it has power. Thanks. TN ROCKS
Old 09-25-2006, 10:57 AM   #7 (permalink)
Curry's Avatar
Make sure you don't cheap out on the wire! You don't want any fires or bad wiring.
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 10:50 PM
Quick Factory Amp Question Anshu Audio, Video, and Security - Tech 5 03-29-2005 08:55 AM
Check out this Amp DrtySthV6SE Audio, Video, and Security - Tech 0 12-24-2002 11:10 PM
