Problem with battery terminal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2006, 03:26 PM   #1 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
Ok so I recently installed my stinger terminals maybe 5 weeks ago or so. on the positive terminal around the ouside theres green stuff all around it. I tried to scrape some of it off and the stinger terminal looked like it was rusting underneath? or it was just copper or something... Anyone know whats going on there?
I plan on getting rid of the battery pretty soon, I'll be installing an optima red top... I just want to know if this is a major problem and if it should be address imediately.
I remember reading about this somewhere but I couldn't remember the term or what the problem was that the person had, which is why i posted here..
I would take a picture but recently my camera went missing (Or stolen ) , so if i find it ill post a pic up, but im sure someone may know what im talking about.
Thanks.
Curry is offline   Reply With Quote
Old 09-18-2006, 06:40 PM   #2 (permalink)
Del The Funky One
Delay_FTB's Avatar
View Delay_FTB's Photo Gallery
Thanks.
Well, depending on what it is exactly, it may or may not be a big thing. If you're replacing the battery soon, I wouldn't worry about it. Just clean your terminalrs real well before putting them on the new battery. Its either a type of corrosion, oxidation or possibly, a leak (doubtful, but a possibility). The sooner you swap the battery, the better off you'll be.
Originally Posted by cam2Xrunner
With a bangin sound system, Carputer with online connection, 1+ lateral G's, and a Twizler Dispenser. That's pimp right there.
Delay_FTB is offline   Reply With Quote
Old 09-21-2006, 10:39 AM   #3 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $132020
View mazdaverx7's Photo Gallery
ther terminals are corroding. remove the cable(s) and get some battery cleaner with neutralizer. spray the stuff on there and let it sit. it'll foam up. use a wire brush and clean the terminals and battery posts. reinstall the terminals with some colored discs that you should aquire when you purchase teh cleaner from teh parts store. the disce are red and green. they prevent corrsion.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 09-21-2006, 04:55 PM   #4 (permalink)
Curry's Avatar
Whats the reason for it corroding? Bad connections or something? I mean I wouldn't want this to happen again.
Old 09-21-2006, 10:17 PM   #5 (permalink)
mazdaverx7's Avatar
not too much you can do about the corroding. the discs really help. the lead terminals love the corrosion. not too terribly sure what causes it. i'll find out and post back.
85 RX-7 GS 5spd
Old 09-21-2006, 11:27 PM   #6 (permalink)
View thoughthard's Photo Gallery
Goto the parts store and ask them for the "good" battery discs that prevent corrosion. The last ones I got were behind the counter in a small can. These ones are soaked in some sort of anti-corrosion fluid. The ones found hanging on one of the shelfs on the sales floor are garbage.
thoughthard is offline   Reply With Quote
Old 09-24-2006, 12:37 AM   #7 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
To prevent corrosion thinly coat the posts, terminal clamps, lugs and exposed metal around the battery with high temperature and water resistant wheel bearing grease, lithium grease or silicone. I use electrical grease from Lowe's.
To clean the corrosion mix one or two tablespoons of baking soda with a little water to make a paste and apply to the corroded areas. This should bubble away the problem. Wipe clean and dry well. If you live in a humid environment your batteries will have a tendency to corrode faster.
Corrosion is caused by one or more the following:
Dirty or wet battery tops normally caused from expansion of electrolyte from overfilled cells or weeping from faulty battery terminal seals
Acid fumes leaking through the vent caps, which could be a sign of overcharging
Not enough battery box ventilation
Electrolysis due to the mismatch of metal alloys used in the battery posts, lugs, terminal clamps or terminals
Pb is offline   Reply With Quote
Old 09-25-2006, 10:58 AM   #8 (permalink)
Curry's Avatar
Thanks everyone for all the info. PB I will try that on my terminals until I get the new battery and see if it helps. I remember it being humid that day so I guess that could be it... who knows. I just can't wait to get my new alternator and batteries. Having to jump start my car is a pain in the ass.
Old 09-25-2006, 09:03 PM   #9 (permalink)
View mikegett's Photo Gallery
Good posts. I use high temp silicone and the corrosion disks. One other thing to mention about the corrosion. Poor contacts on the terminal will cause a increase in amperage as the current tries to pass. This will cause (normaly) a green oxidation. It is very common on high voltage applications drawing excessive amperage. Other terminal oxidation tends to be a white to off white collor. If your terminal posts were scored, or your terminals weren't propperly mounted it could have easily caused the green oxidation. Since you recently installed the terminals, I am guessing you had a poor connection. Be very carefull. This type of oxidation means that your system is pulling much more amperage than what your teminals like. Since you don't have a fuse at the battery, a fire can result. In most cases, the fuse will blow and shut off your system. However, if you are pushing a rather large fuse, the added current could over exceed the cable. When you install your new battery, be certain not to cause gauging in the posts. Double check all connections for tight fit.
mikegett is offline   Reply With Quote
Old 09-27-2006, 10:06 PM   #10 (permalink)
Curry's Avatar
This definetly sounds like the problem. I will have to double check the connection on the positive terminal then. The other terminal is fine. The fust is a 250 amp and wiring is 0guage, but tomorrow I will be going to pick up that new batt.
05 Corolla starting problem phil 9th Generation (2003-2008) 676 04-07-2011 11:47 AM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 12:14 PM
battery leak eating engine bay... (and weird CD player problem) brownyy Camry & Solara Lounge 17 04-18-2006 12:28 AM
Stereo problem after a new battery... redfrecklegreen Archived Corolla threads 0 01-02-2006 09:00 PM
More on this damn car battery! speedemn Camry & Solara Lounge 14 01-01-2006 10:21 PM
