Remote Start Help (Viper 160XV) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2006, 07:30 PM   #1 (permalink)
Gameroom cash: $255930
View LE05's Photo Gallery
Gen5 Remote Start Help (Viper 160XV)
like the thread title says, i need help with installing a Viper 160XV remote start on a 2005 Camry LE.
according to the manual, i am supposed to:
1) cut the starter wire, then
2) connect said wire (going to the starter motor side) to the purple starter output wire, and
3) connect said wire (going to the key ignition side) to the green starter kill wire.
This i understand perfectly... however, the camry has TWO starter wires. one wire is thicker than the other... clearly the thicker one is the main starter wire. my question is, do i hook up the secondary starter wire in the exact same way as the main to the remote start wires?
also... what is the best location for the antenna? if you have pictures, that'd be great!
TIA
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 09-21-2006, 10:22 PM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $132020
View mazdaverx7's Photo Gallery
the best location for the antenna is going to be in the upper left corner of the windshield. inside of course. you'll only need to cut the thicker wire as its the primary. this should help a ton: this is the diagram for a remote start for the 05 camry from directsoft. this is the program i use at work when i install a remote start.
12volts
white/red (30A), white (5A)
ignition harness
Starter black/white + ignition harness Second Starter black/yellow + ignition harness Ignition black/red + ignition harness Second Ignition black/yellow + ignition harness Third Ignition N/A Accessory blue/red + ignition harness Second Accessory N/A Keysense blue - ign harn or BECU, top plug, pin 19 Power Lock blue/yellow - DKP or bottom of fusebox, 20 pin plg Power Unlock blue (double pulse) - DKP or BECU, top plug, pin 22 Lock Motor blue/red 5wi DKP or bottom of fusebox, 13 pin plg Unlock Motor blue/black 5wi DKP or BECU, bottom plug, pin 11 Parking Lights+ green + DKP or bottom of fusebox, 20 pin plg Parking Lights- red - switch or BECU, top plug, pin 8 Hazards lt. green/black - switch or BECU, middle plug, pin 10 Turn Signal(L) green/white + turn signal flasher relay in DKP Turn Signal(R) green/yellow + turn signal flasher relay in DKP Reverse Light red/black + DKP or bottom of fusebox, 20 pin plg Door Trigger see notes - see notes Dome Supervision green/red - ignition key cylinder light Trunk/Hatch Pin green - DKP or BECU, bottom plug, pin 6 Hood Pin black - theft deterrent ECU behind glovebox Trunk/Hatch Release white/blue 5wi DKP or BECU, bottom plug, pin 12 Power Sliding Door N/A Factory Alarm Arm arms with lock Factory Alarm Disarm disarms with unlock Disarm No Unlock use key sense wire Tachometer black/orange ac ECM behind glovebox Wait to start N/A Brake Wire green/white + sw or bottom of fusebox, 20 pin plug Parking Brake red/white - parking brake switch Horn Trigger green/black - sw or bottom of fusebox, 24 pin plug Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 09-21-2006, 10:26 PM   #3 (permalink)
mazdaverx7's Avatar
if you have a chipped key you will need another key and a universal transponder. you also will need a relay for this remote start.
85 RX-7 GS 5spd
Old 09-22-2006, 12:16 AM   #4 (permalink)
thanks for the help!
so i won't need to touch the secondary starter wire at all? i tried installing the BOA 165B remote start... but didn't work for some reason... so i have the wiring information from that kit. i don't believe i have an immobilizer (valet key is a bare metal key) and i believe the remote start comes with a relay.
2005 Camry "LE"
Old 09-22-2006, 07:56 PM   #5 (permalink)
mazdaverx7's Avatar
for the secondary starter wire, you will need to use the violet on the satellite harness, which is the 200mA starter output and connect a relay to the violet and then into the secondary starter wire. you need the relay because 200mA isnt enough to trip that starter wire.
85 RX-7 GS 5spd
Old 09-22-2006, 08:12 PM   #6 (permalink)
thanks mazdaverx7! you've been a great help... much appreciated!!
EDIT: two last questions, then no more from me, lol. 1) what is the DKP and where is it? 2) do you recommend using the tachometer input or the voltage input as the engine check?
Thanks again!
2005 Camry "LE"
Old 09-22-2006, 08:26 PM   #7 (permalink)
mazdaverx7's Avatar
any time man. let me know if there's anyting else i can help you with. if you have time, check out www.the12volt.com its a neat site!
85 RX-7 GS 5spd
Old 09-22-2006, 11:15 PM   #8 (permalink)
just got two last questions in my above post... then i should be good to install the remote start. thanks for the link, seems like there is a lot of good info there!
2005 Camry "LE"
Old 09-23-2006, 12:55 AM   #9 (permalink)
mazdaverx7's Avatar
you should be good at that point. if you have a chipped key, make sure you get the transponder and second key.
85 RX-7 GS 5spd
Old 11-09-2006, 04:26 PM   #10 (permalink)
mark01020304's Avatar
View mark01020304's Photo Gallery
Unhappy
12volts
ignition harness
these reply is really helpful, thanx in advance. but i found that some "note" and linked document is from www.directechs.com. i had checked around, can't figure out how to access to these document. so do i have to register on it or make purchase, then i can get a login pwd?
mark01020304 is offline   Reply With Quote
07 camry w/ Remote start??? why???? profuse007 5th & 6th Generation (2002-2006 & 2007-2011) 14 07-12-2006 08:10 PM
99 camry remote start problem. help klex Camry & Solara Lounge 2 06-15-2006 02:33 PM
Remote Start issue? Hondas2000tuner 1st Generation (1995-1999) 5 04-15-2006 11:47 PM
Remote start??? radicalwillie 1st Generation (2000–2006) 3 11-27-2005 07:57 AM
Installed Remote Start in a 1996 camry, now transmission mal critikal 3rd & 4th Generation (1992–1996 & 1997–2001) 4 01-03-2002 10:29 AM
