Sound gets less loud - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2006, 05:33 PM   #1 (permalink)
Man of the Year
View haschen's Photo Gallery
My system bumps but then after like 5 minutes doesnt hit as hard...AND NO im not just getting used to it. thanks
haschen is offline   Reply With Quote
Old 09-25-2006, 08:44 PM   #2 (permalink)
View mikegett's Photo Gallery
Have your alt and battery tested. It sounds as though one or the other is having a hard time keeping juiced. Be aware, a bad battery will cause your alt to overwork and fail prematurely. Just as a bad alt almost always damages the battery. Have both tested. If both are bad and you only replace one, it will ruin the new part as well.
mikegett is offline   Reply With Quote
Old 09-25-2006, 08:53 PM   #3 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
Your amp could be overheating and malfunctioning. What kind of amp and ohm load are you running?
Pb is offline   Reply With Quote
Old 09-25-2006, 09:10 PM   #4 (permalink)
It is a good possibility. Are your subs shutting down entirely? I have never seen a amp reach protection without shutting off. If they are simply getting quieter, I would check the voltage. Autozone will do it for free.
Old 09-25-2006, 10:36 PM   #5 (permalink)
Man of the Year
My sub is running on a 400watt bridged US acoustics Amp...dont know the ohm load.
Old 09-25-2006, 11:24 PM   #6 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $132020
View mazdaverx7's Photo Gallery
ohm load is very important to know, especially when bridging. the amp could be going into protect mode...check your gain, make sure it isnt cranked..thats not a good. also, if there's too much of a load on the alternator and you dont have a capacitor, the amp will shut down, going into protect mode.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 09-26-2006, 04:11 PM   #7 (permalink)
Man of the Year
if it goes into protect mode wont my sub stop running? and wont the LED light change color? by capacitor ur talkin about a power cap right? thanks
Old 09-26-2006, 07:26 PM   #8 (permalink)
Correct. That is why I stated to check and see if your sub actualy shuts down. If not, then it probably isn't a protection state. Not all amps have a led for protection, but I have yet to find one that won't shut off entirely. I still suggest to have your electrical tested. Your wattage is all deependant upon the amount of voltage being fed into it. This is why most amps will never put out what they rate it at. Most will be rated for 14.4 volts supplied. This is what your altenator should be putting into your battery. Since your battery displaces 12 volts, you will lose about 10 percent of the rated power. If your altenator is not putting out 13.4 -14.4 volts, then your battery will be working harder to keep a 12 volt charge. As you use the system, your battery drains and can't keep up with your music. Once again, it is free to have it tested. If you wait, you could end up hurting the alt and battery. A cost of over 3 bills for parts alone.
Old 09-27-2006, 03:10 AM   #9 (permalink)
mazdaverx7's Avatar
capacitor, power cap, yep same thing. when your subs hit, do your lights dim or does any of the electrical system components seem like they're slower?
85 RX-7 GS 5spd
Now squeaking sound, wat's next? CCCP Camry & Solara Lounge 3 06-18-2006 02:16 PM
Finally got the sound that I was looking for. (Exhaust) trdspeedwayblue 2nd Generation (2005+) 21 07-17-2005 03:05 PM
Hollow Clanking Sound MetalMatrix Camry & Solara Lounge 2 07-14-2005 12:05 AM
'96 LE Engine revvs too loud!!! janeir36 3rd & 4th Generation (1992–1996 & 1997–2001) 25 12-25-2004 04:17 PM
Rattling sound at low rpm (AE92 4A-FE) ssrrww Archived Corolla threads 13 11-23-2004 11:14 AM
