cant get battery ground wire bolt off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-26-2006, 12:35 PM   #1 (permalink)
corollapride's Avatar
View corollapride's Photo Gallery
Hi I am trying to install an amp but I cant get this ground wire bolt loose. Is there a secret way of getting a regular bolt off or can I cut it off?
corollapride is offline   Reply With Quote
Old 09-26-2006, 02:19 PM   #2 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
why do you want the battery ground off? are you grounding your amps to the battery's neg post? if so, you can just use the chassis
WhiteRabbit is offline   Reply With Quote
Old 09-26-2006, 08:28 PM   #3 (permalink)
I need to hook the power wire to the amp. I need to disconnect the negative battery terminal to prevent everything from short circuiting.
Old 09-27-2006, 02:11 PM   #4 (permalink)
Del The Funky One
Delay_FTB's Avatar
View Delay_FTB's Photo Gallery
Hit the gym, LOL
Originally Posted by cam2Xrunner
With a bangin sound system, Carputer with online connection, 1+ lateral G's, and a Twizler Dispenser. That's pimp right there.
Delay_FTB is offline   Reply With Quote
Old 09-27-2006, 02:23 PM   #5 (permalink)
TN's furry friend
o ok, try some liquid wrench or wd-40 i guess
and alot of muscle!
Gen 5 amp ground wire (specific to camry) Frugle 5th & 6th Generation (2002-2006 & 2007-2011) 3 04-13-2006 12:02 PM
More on this damn car battery! speedemn Camry & Solara Lounge 14 01-01-2006 10:21 PM
good or bad ground wire?? cman2000 Camry & Solara Lounge 11 12-07-2004 07:35 PM
Loose ground wire search 1989 gipper89 3rd & 4th Generation (1992–1996 & 1997–2001) 7 12-06-2004 12:26 PM
Help with a Ground Wire kit for '03 & up corolla EMEX Archived Corolla threads 1 11-16-2004 04:46 AM
