Help me spend $500 on Bass - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2006, 07:56 PM   #1 (permalink)
View agent2099's Photo Gallery
I have a 2001 XLS with the premium JLB Audio. I've had two subs in the rear deck crap out on me so I realize I'll finally have to get an external unit.
I am thinking about the following:
Kicker 300-Watt 40Ohm 10" $71.99 + Kicker 2-channel Amp 06x2002 $95.49+ MTX 10" Enclosure $49.99 = $217
Labor = $61
500 Watt Radioshak Amp kit = $40
MET Line Output Converter = $20
Total: $338
This will be used primarliy for Rap and some occasional Rock/Jazz so I would like the bass to be as clean as possible. As I understand it I should stay with a 10" or smaller woofer. I also don't need others to hear my music, but I do want to be able to crank it up and have it sound good while I'm in the car.
I plan on having this installed at CC but am open to other suggestions. Could I find a better deal on these parts or better parts elsewhere?
agent2099 is offline   Reply With Quote
Old 11-13-2006, 08:28 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
if you go down to 11st and central i bet you can get everything cheaper there
Old 11-13-2006, 09:31 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Check out the products on this site:
http://www.edesignaudio.com
11kv2 D2 sub $65
Nine.2 amp: $215
Enclusure: $85 or $55 w/o carpet
http://www.knukonceptz.com for wiring. I would suggest a 4gauge kit for the above amp.
2007 Camry 2.4L 5M
Old 11-13-2006, 09:58 PM   #4 (permalink)
Thanks for those suggestions. I am most inclined to replace the sub and enclosure and (overpriced?) wiring.
Is the Kicker amp not a decent value for the price?
Old 11-14-2006, 01:50 AM   #5 (permalink)
View 94CoupeV6's Photo Gallery
You're not gunna get the best sound from those Kickers. Kicker makes great subs, but those are there cheap models. I say spend a decent amount of money on a sub. I will go all out and recommend one 10" Alpine Type-R. It will give you very good bass that is nice and clean n crisp. Also, it will last quite a long time. Kenwood makes a perfect amp for it, which is a 9102D I believe. It's a 1700W max amp and 850W RMS and is on Ebay for $120-150. The 10" Type-R is 1500W max and 500W RMS. Ebay also has cheap boxes and wires. I'm recomending this to you because I have a 12" Type-R with the Kenwood amp I was talking about and got it all on Ebay including a nice 4 gauge Power Acoustik amp kit for $40 (wonderful deal), a box which was like $30 or so, and a Power Acoustik 1.2 farad capacitor for around $40. I got EVERYTHING for around $400 and for that price, NOTHING will beat that setup. It sounds very, very nice and will be the best sound for a relatively low price setup.
Just thought I'de make a recomendation (I work at Best Buy, I'm used to talking a lot about this stuff). But to be honest use Ebay man, screw any retail store. You'll spend half the price for the same new products.
I'll shutup now though...goodluck with your setup.
94CoupeV6 is offline   Reply With Quote
Old 11-15-2006, 09:23 PM   #6 (permalink)
View rhodes588's Photo Gallery
I have 2 10" type r's wired in series, a ma audio 1000watt mono block, and a 3.0 farad cap. Sounds great
rhodes588 is offline   Reply With Quote
Old 11-16-2006, 08:40 PM   #7 (permalink)
96coupe thanks for the suggestions. I think I am going to take your advice and buy everything online.
I have a question about the enclosure. Is there any specific type of enclosure I should look for. Will any 10" enclosure fit a 10" sub, and 12" w/ a 12" sub etc?
I am strongly considering some of the components you already listed i.e. the Alpine type-r. What reputable online stores do you recommend I purchase from?
And what reasonably priced enclosure will be a good match for a 12" Type-R?
Again I am still sticking within my budget but I realize I’ll get allot more equipment for the money if I buy online (which isn't a surprise as I buy nearly EVERYTHING else online). I just don't know much about car audio so was hesitant about purchasing the wrong things. Now that I have an idea of what I need I'm going to buy all the hardware online and have a local shop install it.
Old 11-17-2006, 12:57 AM   #8 (permalink)
Different subs need different size enclosure. Be sure you get the right size. Either that or you can, or have someone, build you a custom one. If you are inclined and have the tools, an enclosure is easy to build.
You want the enclosure to be no less than 5/8", preferably 3/4" or thicker, MDF.
Sealed or ported is personal preference.
2007 Camry 2.4L 5M
Old 11-17-2006, 10:18 AM   #9 (permalink)
I'm Cam'd Up
Pimpinda93camry's Avatar
View Pimpinda93camry's Photo Gallery
Well for that sub you'll need a specific cu ft of volume. Find that and get a box for that size(volume and Sub Size). bets idea is to go to a store and listen to some subs u are interested in and then buy online.
Hope you find what you like
****NEW 1970 CHEVY NOVA**** MORE INFO LATER
Cold Air Intake
Cat Back Muffler, 5% Semi Matelic Tint
16x7 Proline Alloy, Dunlop SP FM901 225/50/R16
Clarion HU, JL Slash 500/1 , 2 JL 10W0, Silver Star Headlights
Pimpinda93camry is offline   Reply With Quote
Old 11-17-2006, 11:46 PM   #10 (permalink)
Unfortunately most of the time the shops around here don't even have the equipment hooked up properly so you can demo it. And sometimes I feel guilty taking up a salesman's time if I have no intention of spending money at their place of business.
Anyway I couldn't take waiting any longer and I wanted to make sure what I got was compatible with each other so I pulled the trigger on this:
http://www.crutchfield.com/S-eCMwekB...12&i=700BSTG12
Is this a good choice?
Bass in sedans - Camry fredster34 Audio, Video, and Security - Tech 19 05-21-2006 12:18 AM
My girlfriend says she will spend up to $500 on my truck for Christmas LiquidClen Audio, Video, and Security - Tech 44 10-27-2005 12:13 AM
Bass tube? MDKonecky Audio, Video, and Security - Tech 16 04-08-2005 09:19 PM
Brand New RFX9020M Skipping From Bass Tricache Audio, Video, and Security - Tech 3 12-23-2004 11:07 AM
