RS3200 Alarm setting. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2006, 02:36 PM   #1 (permalink)
View PeakXV's Photo Gallery
Did the following and it worked but how do I actually arm the alarm? Just by pressing the lock button ... if so it doesn't seem to be working.
1. Start with the following conditions: you are seated in the vehicle
a. Key is out of the ignition.
b. Drivers door is open, all other doors are closed.
c. Drivers door is unlocked.
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. cycle the power locks 5 times, evenly spaced and relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. cycle the power door locks 5 times. (Same as before)
b. Turn the ignition to on, then back to off.
c. Turn the ignition to on, then back to off.
d. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (automatically) indicating successful entry into programming mode. Return to STEP 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a. Press the lock and unlock buttons on the transmitter simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once indicating successful programming. If the door locks don't cycle, or cycle twice, repeat steps 6a and 6b - this remote has not been accepted.
c. Repeat steps 6a and 6b for each transmitter that will operate this vehicle, including any old transmitters.
7. Close the driver door.
PeakXV is offline   Reply With Quote
VIP RS3200 alarm sensitivity --Moe-- Audio, Video, and Security - Tech 3 08-06-2008 10:41 AM
rs3200 plus factory alarm badazzlegnd 2nd Generation (2005+) 0 09-18-2006 10:03 AM
RS3200 Alarm moisheh 2nd Generation (2005+) 5 05-08-2005 08:57 PM
Setting Stock Alarm / Glass Breakage Sensor, Need Help Please!! skewe Audio, Video, and Security - Tech 19 04-29-2005 07:59 PM
Gen 4.5 Setting Stock Alarm / Glass Breakage Sensor skewe 3rd & 4th Generation (1992–1996 & 1997–2001) 3 03-07-2005 07:09 AM
