Whats causing this.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2003, 09:18 PM   #1 (permalink)
View lankanprince's Photo Gallery
OKay.. here goes...
I have 2 12" subs, running off a kenwood 929 Amp (1000 watt)
I have a voltmeter, and when the bass hits... the voltmere will go from 14+ to ~12.5... and there is no more bass...
Its hard to explain,,, the bass line will start.. and then stop... and once the heavy bass line is done.. the voltmeter display moves up to 14 again.. and the subs produce bass once again...
I have a capacitor too...
Do you guys know whats causing this.. is there something wrong with my amp?
The reason I ask is becuase I just got a new amp... its a high current amp and its going to suck alot of power... so I wanted this to be fixed..
any help would be appreciated
thanks, in advcance
Varan
lankanprince is offline   Reply With Quote
Old 05-24-2003, 10:58 PM   #2 (permalink)
View mach_y's Photo Gallery
your power and ground wires are too small. Upgrade those.
mach_y is offline   Reply With Quote
Old 05-25-2003, 01:22 AM   #3 (permalink)
they are 4 gauge.... thats more then enough
Old 05-25-2003, 02:30 AM   #4 (permalink)
I smell McNuggets
[SMAN]'s Avatar
iTrader Score: 7 reviews
View [SMAN]'s Photo Gallery
DOes the amp flash any colors or anything indicating a power failure? if not, it jsut might be defective. See if the palce u got it from will swap it out for a test.
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
[SMAN] is offline   Reply With Quote
Old 05-25-2003, 03:42 AM   #5 (permalink)
In Ur MOM's Pants
RedruM's Avatar
View RedruM's Photo Gallery
whats the setting on your amp??
if its at max i'd suggest you turn it down
but most likely you're not getting enough power to your amp
i had the same prob but just changed wiring to 2gauge braded wiring
keep the signatures clean please
RedruM is offline   Reply With Quote
Old 05-25-2003, 11:34 AM   #6 (permalink)
It never used to do it before... I dont know wahts wrong...
Well see if it does the same thign with my new amp...
Old 05-25-2003, 06:00 PM   #7 (permalink)
View oibone781's Photo Gallery
Look to see if the sub is properly connected to the terminal inside the box, connection on the inside is inferior, comes loose every now and then.
oibone781 is offline   Reply With Quote
Old 05-25-2003, 08:11 PM   #8 (permalink)
you might have a poor power connection. Check your ground connection especially.
Old 05-25-2003, 08:56 PM   #9 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
This might sound wierd, but after checking your ground and power connections as the guys suggested earlier...replace your in-line fuses.
Something similar happened to me before. I was was having irratic power similar to what you're experiencing. After checking all my connections and not being able to isolate the problem. I swapped the in-line fuses. Although the fuse was visually intact, when I switched it with another one everything worked fine. Still puzzled, I put the bad fuse back on and sure enough the amp started acting up again.
I can't explain what the reason was, but if fixed the problem.
Phi is offline   Reply With Quote
Old 05-25-2003, 11:04 PM   #10 (permalink)
Well... I;m not 100% sure what it was.. but i fastened all the power wires (to the fuses and what not), I tightened the ground wires... and i also chaned the fuses.... and
VOILA.... its all good again
Thanks so much....
