Need Amp/SUB wiring help? ASAP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2006, 03:16 PM   #1 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Can I wire a 4 ohm DVC in parallel (=2ohms load) onto a 2 channel amp bridge? From my research it seems not, but I want a defniate answer.
http://www.xclusive.bz
Old 12-06-2006, 03:45 PM   #2 (permalink)
View rexrunner's Photo Gallery
ya you can do it but it will put a 1 ohm load on the amp. what kind of setup do you have? also if you wire the sub in series (8ohm load) it will only put a 4 ohm load on the amp.
rexrunner is offline   Reply With Quote
Old 12-06-2006, 04:41 PM   #3 (permalink)
View thoughthard's Photo Gallery
Depends on your amp. My Soundstream Reference 300 I had could handle a ½ ohm load bridged.
thoughthard is offline   Reply With Quote
Old 12-06-2006, 06:27 PM   #4 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
all you need to do is verify that the amp will handle a 2ohm load when bridged...
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 12-06-2006, 06:44 PM   #5 (permalink)
cam2Xrunner's Avatar
Most two channel amps when bridged are only stable to 4 ohms, some higher end amps are stable to 2 and one ohms.
What amp do you have?
The safest way to wire this up is by wiring it in series to show an 8 ohm load. Like this.
You will get half the power available, but you won't fry your amp.
One alternative in your situation is to buy another sub. Then you can run them in series like this.
You will be running at a safe 4 ohm load and getting the same power to both subs as you would for one @ 8 ohms.
If you don't want to buy another sub I would use a ported enclosure for more output and run it at 8 ohms.
Old 12-09-2006, 06:47 AM   #6 (permalink)
dna59's Avatar
Thanks for the replies guys. My amp can run at 2ohms, but not bridged. I didn't wanna run them in series, so I just wired each voice coil to a channel.
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
Replacing head-unit on JBL system - wiring diagrams? explorer626 Audio, Video, and Security - Tech 1 02-06-2005 12:40 PM
Stock HU wiring color confusion.. rainman Audio, Video, and Security - Tech 1 02-02-2005 03:17 PM
'97 4Runner Limited wiring questions 97Ltd4Runner Audio, Video, and Security - Tech 1 06-22-2004 11:01 PM
head light wiring.. Jzs147-RR Archived Corolla threads 0 08-27-2003 07:26 PM
