2 amps?
Ok... I think your a little confused. Let me explain
The wiring harness is designed to bypass (get rid of) the amp that is already in your car. So basically assume that amp is not there anymore.
The wiring you have looks to be the exact same as the one xet using anyways. All of the wiring harnesses say they are designed for 83+ toyota's.
You would need to solder that wiring harness to your aftermarket headunits wiring. Then there are two plug-ins toward the back of the spot where your stock radio is, that should fit directly with the wiring harness you bought.
I honestly dont get what you mean by the oem plug. You shouldnt need that anymore if you are installing a new headunit.
The amp inside your car will now be un-used, and your amp built internally into the receiver will be your new power source. Understand...
If you need more help talk to me directly in a PM. I have an XLE just like you so I can help you out.
Originally Posted by CX889
So you mean the harness xet show me should work then? So bypass factory amp and receiver has it own amp internally meaning the 2 amps will still function?
