got system installed, AMP FRIED the next day! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2003, 11:55 PM   #1 (permalink)
pimptronic
View angelox's Photo Gallery
yup, i got an amp, deck and subs installed in my car...
it was done late at night, so i never got to test my shit out, so the next morning i thought id see how it all sounded....
so i'm driving along, arrive at my cousin's house...... then all of a sudden, i hear sizzling...and a shit load of smoke coming out of my amp. like FUK, 30 mins of using my NEWLY installed system.
this wasn't some fleamarket amp, it was the Pioneer Premier PRS-X720 Amp (competition series)...worth $600 US.
so ya i take it back to the installer, and they claim it's simply a defective amp? and it probably was...
does anyone else know what other causes there could be?
-= angelo-x =-
2003 Toyota Corolla S (black)
angelox is offline   Reply With Quote
Old 06-02-2003, 11:57 PM   #2 (permalink)
View tavalon's Photo Gallery
it possibly be the install itself. take it back to where u got it install and they should replace it or give u a refund
tavalon is offline   Reply With Quote
Old 06-03-2003, 01:58 AM   #3 (permalink)
The terrorist
View Xenon's Photo Gallery
Technically your amp should not short out if the right fuse is used before the amp, check the fuse on your amp, and check the fuse they used on the power cable. If the fuse on the power cable is larger amperage than the one of the amp then it is their fault. Other wise the amp was a defective amp.
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
Old 06-03-2003, 09:11 AM   #4 (permalink)
pimptronic
i got it done at futureshop cuz i needed receipts.
they said that it was the amp. the fuse they used was a Stinger Pro 150A..... and i believe the amp is 90, but i'm not to sure.
none of the fuses blew...
i'm not to sure but i know on the amp there is 3 fuses in a row that say 30A..... which ='s 90
xenon what u think
-= angelo-x =-
Old 06-03-2003, 11:22 AM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
I'm using an 100A main fuse ANL-type, which is the black flat one. thats there with my battery.... Then at the rear end, where my powersplitting block is, theres 2 40amp glass (AGU) fuses, and both of my amps have 40amp plastic fuses in them.
Old 06-03-2003, 11:26 AM   #6 (permalink)
View prophesized's Photo Gallery
150 is too much if youre amp only pulls 90 amps. you should have a 100 amp fuse at the battery.
prophesized is offline   Reply With Quote
Old 06-03-2003, 05:48 PM   #7 (permalink)
View mach_y's Photo Gallery
no joke... that shop sucks if they put a 150 amp fuse to protect an amp that can draw at MOST 90 amps. I normally underrate my fuses to protect equipment... because I know I never run my amps anywhere near max current draw. I'd put like a 75 amp fuse on the main line to that amp. What was said is correct... the fuses should have blown protecting your equipment. If they didn't, either there was a shorted wire somewhere, or the internal circuitry is bad on the amp. If it is a new amp, send it back to the company, and next time go somewhere else for the install.
mach_y is offline   Reply With Quote
