sub power handling - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2006, 02:14 AM   #1 (permalink)
fredberg's Avatar
View fredberg's Photo Gallery
Gen5 sub power handling
currently, i'm running an Alpine 10" sub with an Alpine amp. it's a dual-voice coil sub, wired to a 2-ohm load. the amp cranks out 400W mono stable at 2 ohms. the sub is rated at only 300W RMS.
i can hear the sub bottom out when i push it to the limit, just to test it. what if I get a sub that can handle 400W or more? it will be better matched to the amp. will I be able to crank it up with no distortion?
i'm jus wondering if handling 100W more will make any difference.
fredberg is offline   Reply With Quote
Old 12-29-2006, 02:52 AM   #2 (permalink)
That One Guy...
View Corollacrazy42's Photo Gallery
Most would say if the sub is built well it should be able to sustain more power then it even reccomends easily.
You actually want a little head room for subs anyway so your amp doesnt have to be driven at its highest settings.
If your bottoming out your sub though, you may have it in the wrong size box.
Corollacrazy42 is offline   Reply With Quote
Lexus History BLUEMEANIE General Lexus Discussion 8 11-25-2011 12:53 PM
What's good, what's not so good(Car Audio Products) cam2Xrunner Audio, Video, and Security - Tech 166 02-03-2010 12:57 PM
Why more power? 02TAC 1st Generation (1995.5–2004) 7 11-30-2006 10:40 PM
Splice/Tap Power - 2005 Camry MrRedPants 5th & 6th Generation (2002-2006 & 2007-2011) 0 11-04-2006 03:41 PM
Power Door locks on a 07 Yaris digink Yaris, Vitz and Echo Forum 2 10-29-2006 08:37 PM
