1)Is there seperate tweeters for the front? If so maybe they're wired up in series and that's y its showing 2 ohms.
2) I know the gen3 Camry's have 2 wires for the power antenna. One is constant and I think the next one is to turn it on and off.
3)If I'm not mistaken its 12v it uses since the dimmer switch varies the voltage supplied between the 12v and ground. I guess maybe the illumination wire only needs to go to the 12v side of the dimmer switch.
Someone feel free to jump in cuz my memory isn't too good
http://www.xclusive.bz
