Need some expert advice, pls. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2007, 02:10 AM   #1 (permalink)
View Jchan's Photo Gallery
Gen5 Need some expert advice, pls.
As the title stated, I am not an expert at sound systems so any advice is really helpful. This is my setup right now.
HU:
Alpine cda9813 w/ 4 volts pre-out; 1 set fronts, 1 set rears, 1 set sub pre outs.
Amps:
one 2-channel fosgate 75.2 35.7 rms x 2 @ 4 Ohm continous 150 rms x 1 @ 4Ohm Mono
one 4-channels fosgate 500x 62.5 rmsx4 @4Ohm cont.; 250rmsx2 @4Ohm
Speakers:
Front BA comp. SX60 6.5" 65rms peak 200watts
Rear Eclispe 6x9 unknown
Sub 10" MTX Blue Thunder 250-300 rms
Currently, I am running the front comp. off channel 1&2 and sub bridged channel 3&4 onto fosgate 500x. The fronts preouts to channels 1&2 and sub preout to channels 3&4. Now, the rear Eclispe speakers are running off from the 2- channel amp. The rear preout is connetted to the 2-channel amp.
Just wander if this set up would maximize the power of the amps. Please any advice is greatly apprecieated. Thanks
02 SE V6
Make some cash!!
www.agloco.com/r/BBFW0796
Jchan is offline   Reply With Quote
Old 02-01-2007, 12:14 PM   #2 (permalink)
View Mr Marv's Photo Gallery
HU:
Amps:
Speakers:
Yes it looks like you are maximizing the power of those amps. As long as everything is installed/tuned properly you should have a nice sounding system there.
Mr Marv is offline   Reply With Quote
Old 02-01-2007, 03:09 PM   #3 (permalink)
Webb26's Avatar
View Webb26's Photo Gallery
IMHO i would set it up a bit different. I would use the components and the rear fill for the 4 channel, annd bridge the 2 channel for the sub. BUt in your case...the sub need the 250 rms from the 4 channel bridged. IMHO, i would rid of the rear fill and just gut out that second amp. Just use the 4 channel with the front comp. and the subs for that amp. and you can wire the rear speakers to the stock amp and just use an xover to mute it a bit. OR you can bi wire your front comps. Which is basically running every part of your comps on one channel for an amp. So basically you are going to use 4 channels for the front and 1 channel for the sub.
Webb26 is offline   Reply With Quote
Old 02-02-2007, 02:25 AM   #4 (permalink)
I think I gonna keep this set up for now. Maybe I 'll change it later in near future. Thanks for the great advice though.
02 SE V6
Make some cash!!
I need all expert opinions advice please! thinkharder Archived Corolla threads 5 03-03-2006 08:38 PM
Pls lend me some advice Aven4231 Archived Corolla threads 12 12-27-2005 12:38 AM
Need expert advice for OIL PAN problem. ecucio Camry & Solara Lounge 8 11-06-2005 05:17 PM
Need some expert advice I.G. Camry & Solara Lounge 4 12-04-2003 01:11 AM
Expert Gofast Advice Needed EuroCamz Camry & Solara Lounge 19 09-05-2003 11:30 PM
