Is it safe to tap into the HU wires for power? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2007, 11:08 AM   #1 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
Hello. I'm installing an add-on navigation system (KNA-g510) for my already installed kenwood HU. It needs a constant power source and ignition switched power source. I was wondering if I could splice into the HU wires for that. Each power source from the navigation system runs on 2 amps. Thanks for your help.
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
Old 02-22-2007, 06:38 PM   #2 (permalink)
View toyomoho's Photo Gallery
Your limiting factor would be current draw (amps). What size fuses do these two sources of power have? Doubt if the draw by the new device is high enough to cause an issue. You can check the rated power consumption of the devices (look on label or in owners book) and add them up. Compare to fuse size.
Old 02-22-2007, 10:08 PM   #3 (permalink)
^Check my first post above. The wires run on 2 amps each. The HU runs on 15 amps. I just hooked them up and everything works fine (so far). Thanks. Any problems you think later?
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 12:48 PM
90 Prizm Engine Removal - the wires? tashirosgt Archived Corolla threads 6 04-20-2006 10:22 PM
plugs & wires Abyss MR2 Forum 10 08-19-2005 12:36 AM
Tercel Clock wires? Help? gezebo Tercel, Paseo, Starlet, and Sera Forum 7 01-03-2005 04:44 PM
