Adding Sub to 97 Avalon XLS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2007, 02:41 PM   #1 (permalink)
View Avalon401's Photo Gallery
Gen1 Adding Sub to 97 Avalon XLS
I have a 97 Avalon with 6 factory speakers installed. I am missing the 7th (Subwoofer). Can anyone tell me what size will fit the factory location? I searched on this board and have some people saying 8" while others say 6". I am also wondering if all of the Avalons are pre-wired for the 7th speaker? If so, am I restricted to a certain watt or ohm subwoofer and where can I find the harness in the trunk?
Any help would be greatly appreciated.
Avalon401 is offline   Reply With Quote
Old 03-06-2007, 09:59 PM   #2 (permalink)
Gameroom cash: $117630
View gideon1331's Photo Gallery
I don't know about a '97, my my Moms 95 (with 6 speakers) is not prewired for the sub. it has the mounting hole for it, and it is for an 8" sub. You would have to either cut the rear deck, or find a replacement one from a car that came with the sub.
My mom's car had one of the old analog phones built into it with the processing unit under the rear seat. The wire was run below the covers on the door sills so it should be easy to run your own wire back there for the sub. Your factory amp (170 watts peak) will not be able to power a sub...at all. I would suggest running a power wire for the sub down one side of the car, and the signal wire on the other side (to avoid interference). Hopefully someone else can help you more with what you should tap into for a signal.
An 8" sub won't produce as much low-end frequencies as a 10" or 12", but it will certainly add a lot to the factory system.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Adding Daytime Running Lights to 97 Avalon bobcrane 1st Generation (1995-1999) 2 04-24-2006 02:11 PM
97 avalon XLS stereo aux input help!!! mglai1987 1st Generation (1995-1999) 6 02-05-2006 05:53 PM
TRD Supercharger for 97 Toyota Avalon XLS dmem1 1st Generation (1995-1999) 8 04-02-2005 05:11 PM
97 avalon XLS parts car in Los Angeles makku 1st Generation (1995-1999) 1 03-02-2005 07:41 PM
