HU on without ground?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2007, 11:15 PM   #1 (permalink)
View Jchan's Photo Gallery
Gen5 HU on without ground??
I just check the ground for the HU due to whining noise and stumbled into something quite confusing. After I removed the ground lead and see if whining was at the ground but turn out nothing change. However, my HU still can operate while the ground is removed. I just don't know how in the world it still operate without ground. I am really confused and the annoying whining still exist. Any feedback is welcome and appreciated.
02 SE V6
Make some cash!!
www.agloco.com/r/BBFW0796
Jchan is offline   Reply With Quote
Old 03-12-2007, 11:30 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $355745
View atobe's Photo Gallery
well the whole car is ground and the HU's chassis is ground as long as those are touching it's grounded
Old 03-13-2007, 12:14 AM   #3 (permalink)
I understand what you meant, but the HU outercasing was not touching any part of the chasis and was not grounded. That 's where I wonder why it's still turn on. Maybe I 'll try to use process of elimination.
02 SE V6
Make some cash!!
Old 03-13-2007, 01:09 AM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
Yeah, the same thing happened in my old car. The radio could be dangling from the dash with the face resting on the shifter with the ground wire disconnected. No metal part of the stereo was touching any metal part on my car.
2007 Camry 2.4L 5M
Old 03-13-2007, 01:43 AM   #5 (permalink)
cam2Xrunner's Avatar
It's grounded by the Antenna.
If you don't listen to radio, try disconnecting it there and give the headunit it's own grounding point. You may also want to ground the chassis to help get rid of noise.
Old 03-16-2007, 02:36 PM   #6 (permalink)
View ID_hauler's Photo Gallery
A lot of people forget that the antenna is a ground and of course a potential source of noise, one reason is a ground loop can be formed because of multiple grounds to the HU. I recall somewhere that there are "antenna ground isolators" to eliminate some specific problems.
ID_hauler is offline   Reply With Quote
installing 4chan amp, hu 12v wiring question p2adan 1st Generation (1995-1999) 1 12-07-2006 09:45 PM
Camry 2007 Aux Input erasat 5th & 6th Generation (2002-2006 & 2007-2011) 42 06-20-2006 10:56 PM
Is it possible to hook up subs to a HU that doesn't have sub outputs? strmagiceet Audio, Video, and Security - Tech 7 06-01-2005 11:39 AM
tC ground clearance with ground effect kit P1no12 1st Generation (2005-2010) 2 04-27-2005 08:37 PM
Question reguarding RCA preouts and HU crossover ajustment userlain Audio, Video, and Security - Tech 3 10-04-2004 12:06 PM
