96 Corolla Rear Speakers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2007, 04:52 PM   #1 (permalink)
View chenj16's Photo Gallery
i have a 96 corolla dx, i tried several attempts to install the rear speakers but to no avail, the furthest i got to was taken pin out and pop off cover of center brake light, popped 3 white plastic pins from under the rear carpet deck in truck, those 3 pins hold the front part of the deck cardboard... the rear part is where i stuck... it seems they are covered by the plastic panel on sides of the car interior where seatbelts go into... i tried to play around with seats.. but no luck.
i searched online, and some information suggest to remove the rear seats, by entire rear seats, does it mean to include the rear deck with brake lights? and with side plastic panel that seatbelts go into? i'd really love to know more about how exactly to remove the seats...
fyi, my specific application is a 96 corolla dx (canadian), there are no STOCK rear speakers, however i can see there's is wiring under the carpet of the rear deck.. and the backseats is a 60/40 split, can be folded down..
thanks a lot in advance!
chenj16 is offline   Reply With Quote
Old 03-16-2007, 02:05 AM   #2 (permalink)
Sleepin zZzzzz
360glitch's Avatar
View 360glitch's Photo Gallery
I don't know anything about the Corollas but I can tell you that to access the rear speakers in my '95 Camry you have to take out the bottom half of the seat, folt down the top, remove the two "cushions" to each side, then pull off a panel on each side, remove the brake light cover (and brake light?) and then remove the entire rear deck. It's quite enjoyable.
'01 Avalon XLS - Project Log
'92 Eagle Talon TSi AWD - Project Log
360glitch is offline   Reply With Quote
Old 03-16-2007, 11:23 PM   #3 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
The process is similar in the Corolla. Take off the bottom seat cushion, remove the pads on the side of the back seat, make sure the seats are folded down, disconnect and remove the center brake light, and then pull up on the front of the rear deck. Once the front is lifted up, you can pull it straight out (with a little beding at the edges). Ive had the rear deck off my car probably a dozen times and the bending doesnt harm anything.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 03-22-2007, 10:58 AM   #4 (permalink)
thanks a lot guys, i'll try it at some weekends when the whether gets warmer.
Old 09-30-2007, 09:08 PM   #5 (permalink)
View Sandman614's Photo Gallery
Thanks, I too will try this and am sure I will be back asking questions.
Sandman614 is offline   Reply With Quote
Old 10-23-2007, 02:17 PM   #6 (permalink)
Ukranian102 in this thread is a huge help.
http://www.toyotanation.com/forum/t64414.html
Old 08-17-2008, 09:04 AM   #7 (permalink)
View coredump4's Photo Gallery
I just had to replace the rear speakers in my Mom's '95, and having this process helped a bunch!
Here are some clarifications to the above process that might help others:
* The rear seat bottom cushion has 2 clips anchoring it down underneath the front edge of the cushion. Just pull up on the cushion to release these clips, then the whole seat bottom slides forward and out easily.
* Removing the rear seat side bolsters is easy. They're held in by a single bolt at the bottom (11mm, IIRC). After removing the bolt, lift UP and out on the bolster; don't pull it straight out.
* Removal of the 3rd tail light is required, unfortunately. There are two plastic lock pins on the light housing. You can probably work them out with a flathead screwdriver, or an upholstery tool. Once the pins are out, the cover comes right off. Then there are two bolts holding the light in place; remove those, and disconnect the electrical plug, and you're done.
* The rear deck cover has 3 clips along the front edge. The clips can be released by hand, but a panel tool might help. After releasing these, you can pull the cover out with a little effort and bending the edges slightly, as the OP mentioned.
* What's tricky about the deck cover are the factory speaker covers, which you do NOT want to remove. Note they are held on by pressure clips and you will likely knock one or two of these off and/or break the clip off while removing the deck cover, so be as careful as you can. Secondly, there is a foam ring around the factory speakers that fits into the covers. You don't need it, but in case you want it, be careful not to tear it when removing the deck cover; in my case, the car's age meant the foam was pretty well deteriorated and falls apart easily.
* One other note about the deck cover. There are 6 metal clips along the back edge that hold the cover in place beneath the rear window. Make sure you seat these clips when replacing the cover. In the picture below, you can see the deck cover's front and rear clips:
* The speakers themselves are standard 6.5" speakers. I bought some Kenwoods for my Mom's car, which were a drop-in replacement, including the wiring.
* If you want to keep the foam rings, a hot glue gun is perfect for gluing them to the new speakers.
* Reverse your steps to re-assemble everything. Here is a new speaker, with the foam ring on (notice the smooshed/torn foam):
This write-up, which I think is for a Camry, also helped me:
http://rayrayonline.bravehost.com/rearspeaker1.htm
Good luck
coredump4 is offline   Reply With Quote
The Following User Says Thank You to coredump4 For This Useful Post:
BrianAbrigana (05-10-2011)
Old 08-17-2008, 10:58 AM   #8 (permalink)
Thumbs up Amazing
Thanks for adding your post on this thread. That is the best explanation on this process i have ever seen, the pictures are perfect and very detailed. Unfortunately I have already found my way into the car I was working on . Again thanks for your support and I'm sure this will help someone out a lot somewhere down the road.
Old 08-17-2008, 05:37 PM   #9 (permalink)
Thanks, hopefully it will help the next person to take on this job.
As a side note, I think I remember the bolt sizes now. I think the rear seat side bolsters actually use 12mm bolts, while the third tail light uses 11mm bolts. Please correct me if I'm wrong...
Old 02-18-2009, 07:04 AM   #10 (permalink)
CmyWebsite.
View pursang's Photo Gallery
This is a really helpful thread, I have to point out your not removing the brakelight cover properly, those buttons have a center pin, you simply push the pin in and the button pops right out. you don't have to pry on them at all. excellent photo's btw.
1990 Toyota Corolla.
1981 Toyota Pickup 22R auto 2wd.
1999 Yamaha XT600E.
pursang is offline   Reply With Quote
Old 06-23-2009, 07:28 PM   #11 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
Those pictures were a great help. thanks.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 12-29-2009, 03:08 PM   #12 (permalink)
View Mineiro04's Photo Gallery
How iremove door panel in corolla 2003 CE
Mineiro04 is offline   Reply With Quote
Old 12-29-2009, 03:09 PM   #13 (permalink)
Remove door panel corolla 2003
How i remove door panel corolla 2003 CE(Manual)
Old 02-16-2012, 10:23 AM   #14 (permalink)
zoobra's Avatar
View zoobra's Photo Gallery
Thanks for this write up. I just bought a 96 DX as a commuter and the speakers were shot. This helped out greatly. Thank you.
zoobra is offline   Reply With Quote
1996 Corolla rear lip or rear bumper (AE102) Jaspher Archived Corolla threads 2 11-24-2006 02:10 PM
Removing Rear Speakers of '90 Corolla eastcoastmowers Archived Corolla threads 3 08-20-2005 05:04 PM
Who has upgraded their rear speakers? emiliorescigno Archived Corolla threads 15 08-12-2005 03:57 PM
2002 Corolla CE, rear deck removal hipstermcgee Audio, Video, and Security - Tech 1 08-05-2005 04:10 AM
05 Corolla rear speakers help Kalei Archived Corolla threads 1 09-18-2004 06:24 PM
