XM radio users: any trouble putting antanna on dash? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-23-2007, 05:30 PM   #1 (permalink)
View sig2269mm's Photo Gallery
I'm looking to put XM in a new corolla, and would rather slip the XM antanna on the dash, in the corner, just below the glass. One installer says it will work without problems, another says reception will be iffy. I'm the San Francisco bay area. Can anyone be of help?
sig2269mm is offline   Reply With Quote
Old 03-23-2007, 08:31 PM   #2 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
With XM, you must have a direct line of sight to the equater for the service to work. If your car is turned in such a way that the antenna cannot have an uninterrupted line to the satellites in orbit above the equater, you will lose signal.
Sirius on the other hand will always work on the dash as well as it does on the roof because the satellites orbit in an actual pattern to get increased coverage with less satellites..
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 04-16-2007, 10:12 PM   #3 (permalink)
View kpopple's Photo Gallery
I have XM and I have noticed that most of the time, it receives a decent enough signal on the dash, but then again, I live in a more rural area.
kpopple is offline   Reply With Quote
Old 04-18-2007, 07:33 AM   #4 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
with mine, the antenna was held down magnetically, and if i didnt have it on a magnetic surface without an obstructed view of the sky, i got terrible recieption.
why dont you want to mount it outside the car?
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 04-18-2007, 09:28 AM   #5 (permalink)
Tommy's Avatar
My garage
Old 04-18-2007, 05:18 PM   #6 (permalink)
I smell McNuggets
[SMAN]'s Avatar
iTrader Score: 7 reviews
View [SMAN]'s Photo Gallery
The reason the antenna works best on the roof is becuase it needs to be above the ground plane. With normal sedans and SUVS, the car's entire frame is grounded, Putting the antenna below a part that is ground will cause the frame to block a large part of the signal. Also, putting it on the dash instead of a large metal surface will also cause issues with the fact that the grounded area for reception is too small. You'll find a lot of this info if you read up about mounting CB antenna's and stuff but the same still aplies here, you may be able to get away with it, but it will work a lot better if it's on the roof. Convertables get awya with this becuase their roof isn't grounded.
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
[SMAN] is offline   Reply With Quote
XM Radio bpaulmd Solara 1 03-02-2007 08:31 AM
XM and Sirius expected to merge PigsEye Off Topic 13 02-19-2007 10:15 PM
xm in trouble? jskicet 2nd Generation (2005+) 4 02-18-2006 03:12 PM
My dash lights went out! xavior66 Camry & Solara Lounge 5 08-03-2004 01:38 AM
Question on dash for the radio? jizzoe Camry & Solara Lounge 2 05-15-2003 10:19 PM
