subwoofer ohm trouble - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2007, 08:04 PM   #1 (permalink)
View thereal2x's Photo Gallery
im having some trouble trying to figure out my friends optimum sub impedence. he has a 2 channel amp and 3 subs. one is dvc with 2 ohm coils, the other is dvc with 4 ohms coils, and the last one is svc 4 ohm sub.
right now its wired with the 2 ohms sub wired as 1 ohm and the other dvc as 8 ohm giving it 4 ohms. and the other subs is on the other channel as 4 ohm.
i want the 8 ohm sub to be getting some more power bc the 1 ohm sub is hogging that channel. is there another way to hook this up?
if i wire the 2 ohm sub as 4 ohms and the 4 ohm sub as 2, how many ohms will that be together? will it be 3 or will it be 1.5?
thereal2x is offline   Reply With Quote
Old 03-25-2007, 10:47 PM   #2 (permalink)
cam2Xrunner's Avatar
You can't use different subs with the same amp. Pick one that works with your amp, either the dual voice coil 2 ohm sub or the single voice coil 4 ohm sub. Bridge the amp channels to power that one sub.
List the brand/model of these two subs so we can see which one is better.
Also if you have a digital multimeter, check to make sure they are all showing the right ohm and not 0 so you aren't running a blown sub.
Old 03-26-2007, 08:35 PM   #3 (permalink)
the 2 dvc subs are jl w3s and the one svc is infinity. they are wired and working fine right now i was just wondering if could get a little more power out of the one jl
the stock speaker is 4 ohm. the one i'm trying to install is 8 ohm. would it be ok? driving90 Audio, Video, and Security - Tech 1 02-24-2007 02:59 AM
trouble, trouble and trouble with 3vz-fe gbaoyn Camry & Solara Lounge 13 04-20-2006 09:26 PM
Amp/s Suggestion To Power These Subs CamryOnChrome Audio, Video, and Security - Tech 22 03-31-2006 10:35 AM
Can I use 4 Ohm speakers where 8 Ohm ones used to be? elixer Audio, Video, and Security - Tech 5 08-16-2004 04:34 AM
