AMP settings question. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-05-2007, 12:08 PM   #1 (permalink)
View Dust Devil's Photo Gallery
On my amp (Alpine MRP-F450) there are High Pass and Low Pass filters and an OFF position.
Are coaxial speakers considered "full Range" speakers?? if so it says to set the switches to the off position.
Also if the switches are "off" does that render the crossover freq adj "off" too?
Dust Devil is offline   Reply With Quote
Old 04-07-2007, 10:39 PM   #2 (permalink)
cam2Xrunner's Avatar
You don't want your coaxials getting frequencies below 60 to 80 hz. So turn the HPF on(High Pass Filter-It lets the highs pass through the filter and blocks out the lows)
Sometimes amps will have what's called a 10X multiplier. If you do have that, turn it off and then set the dial to 60 or 80 hz.
Make sure your gains aren't too high, put the gain at it's lowest setting, then turn up the volume on the headunit about 90-95 percent full volume. From there(with the HPF on and adjusted) slowly raise the gain until you think you hear distortion, when you do hear distortion back off the gain a little.
Old 04-09-2007, 09:01 PM   #3 (permalink)
Thank you !!
Old 04-09-2007, 09:32 PM   #4 (permalink)
Newbie...Don't hate
View jizzody's Photo Gallery
So I'm going to go out on a limb here and say that a low pass filter would be if you had the amp hooked up to a sub?
jizzody is offline   Reply With Quote
Old 04-09-2007, 11:43 PM   #5 (permalink)
Correct.
Also if you are using an Active Electronic crossover you would send a low pass filtered signal to your mids too, but in the case of using coaxials, or a regular component set the supplied passive crossover unit will handle that.
Question About Speakers And Amp umeshr85 Audio, Video, and Security - Tech 0 01-09-2007 07:02 PM
installing 4chan amp, hu 12v wiring question p2adan 1st Generation (1995-1999) 1 12-07-2006 08:45 PM
Real stupid question? WhiteTrash2775 Audio, Video, and Security - Tech 11 07-25-2005 01:52 PM
Amp Question Vato Loco General Discussion 4 08-15-2002 11:57 AM
