Amp won't turn on...? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-05-2007, 03:46 PM   #1 (permalink)
Newbie...Don't hate
View jizzody's Photo Gallery
Question Amp won't turn on...?
Okay, I hooked up my KX350.2 and got it on last night. Then today I tried to install my new sub and had everything working, but then all of a sudden my amp cut off and would not turn back on no matter what I tried. I even took the remote turn on and hooked it directly to the battey. No fuses are blown or anything like that. Any answers?
jizzody is offline   Reply With Quote
Old 04-05-2007, 03:50 PM   #2 (permalink)
Newbie...Don't hate
Alright...I'm an idiot for getting click happy...if you could, please just reply to this thread only...sorry guys
Old 04-05-2007, 04:25 PM   #3 (permalink)
View toyomoho's Photo Gallery
Download the manual and check out the troubleshooting section. Recheck all wiring, did you check the amps own fuse? The vendor might have a technical support line.
http://www.kicker.com/06/tech-suppor...0_2%20Amps.pdf
Old 04-05-2007, 07:14 PM   #4 (permalink)
View thoughthard's Photo Gallery
Did the speaker wires touch somehow?
thoughthard is offline   Reply With Quote
Old 04-05-2007, 08:55 PM   #5 (permalink)
Newbie...Don't hate
They may have, but if that is the case wouldn't it have just blown a fuse? And yes, I did check the amp's fuses and they are okay.
Old 04-05-2007, 08:57 PM   #6 (permalink)
Newbie...Don't hate
I just thought of something....I have a smaller fuse than reccomended. It's a 30 amp and reccomended is 50 amp. Could this be the problem? I mean, it's not blown, but...?
Old 04-05-2007, 09:07 PM   #7 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
if it's not blown then it should be ok. most common problem is ground got loose.
nodrogkam is offline   Reply With Quote
Old 04-05-2007, 10:50 PM   #8 (permalink)
Newbie...Don't hate
Alright...the power wire doesn't have 12 volts comming to the amp. Has 12 volts up until my fuse holder. Must have went bad somehow? Oh well, quick trip to Oreillys or Walmart tomorrow and quick fix. Thanks guys.
Old 04-05-2007, 10:57 PM   #9 (permalink)
nodrogkam's Avatar
if the fuse isint broken then take the cap apart and make sure things have good contact.
hopefully it'll be a quick fix.
Old 04-05-2007, 11:15 PM   #10 (permalink)
View slick07LE's Photo Gallery
That's what I was thinking.
slick07LE is offline   Reply With Quote
Old 04-07-2007, 10:43 PM   #11 (permalink)
cam2Xrunner's Avatar
Sounds like the fuse is blown if you aren't getting power after the fuse. It may look like it isn't blown but it could be. I would go ahead and get the right fuse.
Other things to check for- Is the sub properly matched to the amp? What ohm load sub is it? How is it wired? What headunit are you using and where is your gain set at?
Old 04-08-2007, 01:36 PM   #12 (permalink)
Newbie...Don't hate
I replaced the fuse holder and upgraded it from a 30 Amp to the reccomended 50 Amp and now everything works peachy. I have a Kenwood headunit, Gain and Bass Boost on the amp both set to about 1/4 of the way, amp is bridged (4Ohm) to a SVC Kicker Comp (4Ohm). Thanks guys for all of your help.
Old 04-08-2007, 01:42 PM   #13 (permalink)
^Sounds like it will be reliable.
Old 04-08-2007, 01:43 PM   #14 (permalink)
Newbie...Don't hate
I hope so, thanks for the help.
Old 04-08-2007, 02:01 PM   #15 (permalink)
nodrogkam's Avatar
wow only 1/4 of the way.
well enjoy the new system!
2007 AMP and Sub Install, Who's Done it? phildac 5th & 6th Generation (2002-2006 & 2007-2011) 18 08-16-2006 10:06 PM
Amp wont turn off! haschen Audio, Video, and Security - Tech 3 06-07-2006 06:43 PM
Took out old stereo and found an amp on Gen3 camry!! fernicus 3rd & 4th Generation (1992–1996 & 1997–2001) 9 03-14-2005 01:30 PM
