Originally Posted by SleepersOwn
Hello guys..I have a few questions i'm hoping i can get answered but first i'll give a lil background to make it easier if possible. BTW THIS WILL BE LONG WINDED !!!! LOL.
I'm spanking new to the audio world but i'm learning as I go along. I just purchased a pioneer deh-4900 deck, powering some polk 6.5 6501 components for the front and 6x9 691 for the rears. BTW, this is in a 92 camry. I'm trying to DIY on this project so I installed the deck myself ( pretty easy once i found the right friggin wires... long story ). I took a stab at the 6x9's and realized it doesn't exactly fit without some drilling of the rear pods ( i don't own one ) So, i went and tried the fronts with a friend... We got the speakers to fit as well as the tweeters in the stock pod location but couldn't understand how to hook up the crossover so we said screw it and left it out...needless to say it sounded like complete shit and distorted as hell. ( if laughter generates by reading that, please allow it to subside before continuing ) So.......I just went and got them installed by a shop.
I told them to put the tweeters in the stock door handle pods as i didn't want to put a hole in the A-pillar. I also have the crossover strapped to the door with some zip ties ( i live in phx arizona and i didn't think waterproofing it would be that necessary ). Also, i switched around the lil switch for the db .. it didn't really sound like it did much but ehh, maybe i need an amp to notice a diff...
Now...with this setup, my volume on the deck goes up to 62 max. However, i can only bring it up to around 40-50 the loudest before i start getting pretty noticeable distortion from the speakers. This is with my current settings of loudness set to MID, EQ set to MID 0. This is what i've found by playing with it that is the best i can get as far as a " full " sound at that volume level. If i turn any of the other settings up i get distortion. Now i understand that coaxials in the rear and comps in the front isn't a bass thumper but .. wtf ?
Comment/Question..
Am i doing something wrong ? or is this normal ? I would have guessed that with a deck that only puts out 22rms x4 to speakers that are able to handle 100rms i would be able to have the volume ALL the way up and not hear anything.. input is appreciated.
Comment/Question..
I do plan on getting a 4channel amp ( i'm currently looking at the kicker zx350 and mtx ta3404, tc4004, Hifonics txi4406 and a few others in the $130-180 range ). My guess is that with the amp, i won't have to run the volume up so high to hear it like i want thus defeating the distortion at high volume problem...Am i correct in this thinking ?
Comment/Question..
To round out the rest of my system I plan on getting a nice 12" sub, a mono to power it, and a 1.0 or 1.5 cap.
I was recommended the Alpine Type R in a ported box, if somone could explain the importance/difference between the Dual 4ohm voice coil and Dual 2ohm voice coil, ???? i'd be appreciative.
Last but not least i'm looking at a number of mono's to power that type R if i get it. I'm thinking kenwoods kac 8103D..500rms x2 2ohms and 1k watt max. Sound good ?
Any recommendations on anything i'm planning on getting will be GREATLY appreciated. Also, any help with any of my questions will be appreaciated as well. Thanks in advance.
I'm thinking that the lack of wattage is causing you to lose some control over your speakers, which is why they dont sound the way they should. With an amp you will definatly be surprised with the results. A headunit alone, to me, can't provide a sufficient amount of power to a set of components to really let them shine, it just isnt possible.
Just wait and get a 4 channel and you will know exactly what I'm talking about, I'm pretty sure you will notice the difference like night and day. I have pretty much the same set as you cept the older version. I have a Kenwood HU atm and it only goes to 35, and i barely push it anywhere past 25, but then... I have my amp gains set to that point. Although, at 25 the speakers are just plain loud, and thats just to the point where they still don't have distortion but one click more and they do slightly.
Given I am pretty impressed with the quality my amp has given me, even though I am getting rid of it soon, I will recommend the MTX Thunder 564 to you as an option. Powerful little amp and would be great for all your speakers. Plus I'm pretty sure they go for cheap. I don't know if you can really find one new, but they are good little amps.
You could also try this particular amp, that some people on a car forum I'm apart of have found quite good for the price. It's a Blaupunkt VA4100. Check that one out if your interested. I know there are a few on ebay for a pretty good price too.
As for a sub amp... I wouldnt so much recommend Kenwood. I would reccomend checking out car audio sites such as, Elitecaraudio.com, Caraudio.com, ICIX.com, and diymobileaudio.com for some good deals on some new and used equipment from people who know alot of stuff about car audio (Not so much Caraudio.com, because the people there aren't nearly as intelligent). However I will let you know that Type R's are power hungry little beasts, and most people would say they lack in the SQ (sound quality) range. But it all depends on what type of sound your looking for.
Also, don't get a cap... they do nothing and it has been proven. You don't have to believe me, but thats just another expense you don't need, unless you like having a voltage meter?!?.. in which case that makes the cap even more expensive so.. pretty useless if you ask me.
When you talk about dual voice coil subs either dual 2ohm, or dual 4 ohm... the only difference is the ohm configuration you can put to your amp.
SO you will have to find an amp that will suit either a dual 2, or a dual 4 specifically.
Dual 4 = 2 ohm load on the amp
Dual 2 = 4 ohm load on the amp
but because its dual voice coil, you can configure it it more ways then one, which is also know as running in series... or parallel
so also...
Dual 4 = 8 ohm load on the amp
*(although this is not common on amps, but all amps should be able to run this independence if need be)*
Dual 2 = 1 ohm load on the amp
