Need Help with Remote Wires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2007, 12:04 AM   #1 (permalink)
I Drink your Milkshake
GTCOMA's Avatar
View GTCOMA's Photo Gallery
I am hoooking up a Panasonic headunit to my 05 tacoma
The panasonic has two blue wire remote hook ups.
I need to hook up an amp and I figured out that I need to hook it up to the remote labeled for the amp power.
My question is regarding the other power ant blue wire. My truck does not have a power antenna, but the wire harness adapter I got from Crutchfield also has a wire marked for the ant. I realize it is probably a universal Toyota harness, but I want to make sure there is not another reaseon why I should hook the two Ant remote wires together.
Also there is a loop from the same blue wire on the toyota harness that connects back into itself in another hole. What is that for?
GTCOMA is offline   Reply With Quote
Old 04-24-2007, 12:31 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Hook the blue wire with the white stripe to the amp remote connection.
The blue wire just put some heatshrink or electrical tape over the end so that it doesn't ground on anything.
2007 Camry 2.4L 5M
Old 04-24-2007, 02:47 PM   #3 (permalink)
I smell McNuggets
[SMAN]'s Avatar
iTrader Score: 7 reviews
View [SMAN]'s Photo Gallery
If your power antenna wire is actualy part of the toyota harness, it is probably the turn on for the amplifier for the antenna. These days most new cars have a small amplified antenna instead of a long mast antenna. Don't just skip over it, but if you don't have a seperate power antenna out from the cd player, then you can splice it in with the amp turn on.
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
[SMAN] is offline   Reply With Quote
Old 04-24-2007, 04:13 PM   #4 (permalink)
GTCOMA's Avatar
Thanks for the help. i guess i will see if the harness has a pin tha the wire will connet to, if it does, then I guess i should connect it.
Old 04-25-2007, 10:06 AM   #5 (permalink)
GTCOMA's Avatar
looked at it last night and there is not a coresponding wire in the harnes attached to the truck. So I guess nothing is powered by the remote at turn on/off
Old 04-25-2007, 10:51 AM   #6 (permalink)
The remote wire, blue wire with white stripe, comes out of the back of the stereo not the wiring harness to the truck. It does not connect to anything on the truck. You attach a piece of wire to that and run it to the amp remote terminal.
When you said Panasonic stereo, you did mean an aftermarket unit and not a Panasonic unit made for Toyota right?
2007 Camry 2.4L 5M
Old 04-25-2007, 11:40 AM   #7 (permalink)
GTCOMA's Avatar
Yes, it is an aftermarket stereo.
I figured out what I needed to do with the blue wire with the white stripe, I was just confused on if the solid blue wire really needed to be connected to anything on my truck. It looks like it does not.
Old 04-25-2007, 01:43 PM   #8 (permalink)
If you don't have a power antenna, just put some electrical tape or heat shrink over the end of the blue wire. You won't connect that to anything.
2007 Camry 2.4L 5M
Remote Door Locks flyerboy 3rd & 4th Generation (1992–1996 & 1997–2001) 10 06-13-2007 11:20 PM
How to program keyless remote for 98 camry LE? keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 45 09-14-2005 07:48 AM
How to Get the Remote Control Key Working mhshah Camry & Solara Lounge 3 09-10-2005 10:04 AM
remote starter on stock toyota remote v6secamry Camry & Solara Lounge 6 09-08-2005 11:39 AM
Installed Remote Start in a 1996 camry, now transmission mal critikal 3rd & 4th Generation (1992–1996 & 1997–2001) 4 01-03-2002 09:29 AM
