Camry Audio Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2007, 10:28 AM   #1 (permalink)
View 07CamryLE's Photo Gallery
I have had my LE since September. The last month or so I have noticed i have to turn my radio up very loudly, especially on highways to get sound that can be heard. I need to have it from the low to mid 30's to low to mid 40's. This was never the case before. it is very quiet on siruis, am/fm and cd. If i play with the ASL setting it will get louder but then distort the aftermarket sub. Everythign is original factory except for the Infinity 10" self powered sub in the trunk.....anyone else have this happen?? Any ideas what is going on with my deck and or speakers? Any and all info is appreciated ...thank you!
07CamryLE is offline   Reply With Quote
Old 04-28-2007, 09:35 PM   #2 (permalink)
Dominican Republic
Dj-torn's Avatar
View Dj-torn's Photo Gallery
Where does the infinity get its sound input from? If raising the asl works for the speakers, then go to the sub, and turn the gain or bass boost down, and eq to your liking from there.
Stock 2002 Camry LE: 2AZ-FE: VVT-i
Dj-torn is offline   Reply With Quote
Old 04-28-2007, 10:10 PM   #3 (permalink)
Not a Pre-runner
Twisted Sid's Avatar
Gameroom cash: $387100
View Twisted Sid's Photo Gallery
if everything is original and you have an aftermarket sub then you are probably running lineout converters off the rear to get a signal for the sub. if thats the case then you are loosing alot of sound from the back and its now forcing you to turn it up louder to compensate. when you get it up loud enough to hear on the highway, the signal is clipping so the sub is distorting. to test this disconnect the sub and see if everything goes back to the way it was before the sub install.
'94 Pickup: Std Cab, 22RE, 5spd, 2wd
Front: Total Chaos Uniball Kit, Fox 8''Coilovers, Custom Engine Cage, Hannemann Fenders,
REAR: Deaver F67 Leafs, Fox 14''Shocks, Custom Bed Cage, Glassworks Bedsides, Tacoma E-locker Axle 4:88 31x10.5 BFG AT Tires
Twisted Sid is offline   Reply With Quote
Bookmark these sites(vast supply of car audio info) cam2Xrunner Audio, Video, and Security - Tech 25 08-10-2010 10:57 AM
Techna-fit Brake/Clutch Line Group Buy: All Makes/Models raptorracing Supporting Vendor Sales 230 08-27-2007 12:22 AM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Brake Upgrade Question: will this fit on the GEN 4 Camry?? leasaunce 3rd & 4th Generation (1992–1996 & 1997–2001) 0 04-20-2006 09:24 AM
2005 Camry Door handle Question xpeed 5th & 6th Generation (2002-2006 & 2007-2011) 4 01-04-2005 08:38 PM
