Originally Posted by thereal2x
having it in a sealed box will make it less loud but it can play lower frequencies. if you have it connected to the same amp, the 12 inch one you might feel a little more since there is more cone surface area. put it in a ported box and you will feel the diff. if your going to get a 12" i recommend the alpine type r. i have one in a ported box with a 650rms amp and its loud enough for me.
To let you in on some info (not trying to argue, just letting you know) a sealed box is actually not much more quiet then a ported box. In many tests it has been proven to have a max increade in DB's of around 5db's which in most cases won't really be noticable.
Also sealed doesnt play lower freq... a ported box can be tuned to produce as low of freq as you want, as can a sealed... but a ported box will target that specific tuned point and make it as loud as possible. Sealed in a small box is going to go deep, but ported will always win in the low factor.
The only thing that can be said about ported is that it may make your sub sound different, which you may or may not like... in which case the Type R is a ported beast so more then likely you will like it if you like bass. And yes with around 600-700 watts the type r will be bangin. I've heard numerous times that its just loud then it is clear, but thats all in the install and the listener.
It's up to you but a 12 will more then likely be a better choice if you have the room.
In regards to your statement though,
No I don't think you will really notice too much of a difference.
